Old 12-08-2011, 05:46 PM   #1
lloydautobody
how to install 350 chevy in 62 pickup
I am building a 62 sedan delivery. It came with inline 6 cyl I am installing late 80's TPI 350. How do you go from the frame to the engine mount? Is there a conversion kit for the install???
lloydautobody is offline   Reply With Quote
Old 12-08-2011, 05:59 PM   #2
yumyumchoppers
Re: how to install 350 chevy in 62 pickup
i went to o'reilly's and bought motor mounts for a v/8 62 chevy pickup.
yumyumchoppers is offline   Reply With Quote
Old 12-08-2011, 06:01 PM   #3
yumyumchoppers
bolt in, takes a ram horn exhaust manifold. easier if you remove the perches from the frame and bolt them to the motor bofore installing.
Old 12-08-2011, 09:43 PM   #4
lloydautobody
which engine mount perches will work on this swap?
Old 12-08-2011, 08:03 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum!
Here's a link to how I did a 350 sbc swap in my 1960 GMC. The Chevy and GMC frames are the same 60-62, but the original engine mount towers are different between the makes:
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Old 12-08-2011, 09:51 PM   #6
lloydautobody
that is very helpfull!!!!!!! thanks for the info.I am sure this will work great on the '62
Old 12-09-2011, 01:44 AM   #7
Captainfab
60-66 Nut
The '67-'72 small block motor mount brackets will work quite well on the '60-'62's.
Old 12-09-2011, 11:16 AM   #8
lloydautobody
Thanks for the info. It is good to have unlimited help from people like you when you don't know which way to go. have a great day!!!
Old 06-10-2012, 06:15 PM   #9
Blue Blood
Blue Blood's Avatar
I know this is an old thread, but here goes....I have a 1962 c-10 w/ a sbc i'm trying to mount in. I made 1.250" spacers to go between the motor mount & the top of the frame rail to get the balancer off the center link,that's fine. My problem now is the lower part of the mounts no longer line up with the mounting holes in the crossmember...the motor mount holes are too far 'outboard' ,or towards the wheels. Do I have later (72' up) motor mounts? I need 67-72 correct? The ones in my truck look like 67-72....Thanks!
Edit: I am told this is a 400 ci sbc...though I haven't gone by the numbers on it yet ...my mounts look like the ones in the above pic.
Blue Blood is offline   Reply With Quote
Old 06-10-2012, 09:38 PM   #10
notsolo
notsolo's Avatar
I put a 283 sbc in my 62 with 1/2" spacer on top..(this is on top of 83 crossmember w/disc brakes) ...1.250 seems kind of tall.
notsolo is offline   Reply With Quote
Old 06-11-2012, 04:09 AM   #11
Blue Blood
Blue Blood's Avatar
The usual height guys go with seems to be 1.0" for the spacer, but that was BARELY getting the balancer off the center link, so I went an extra .250"...Which looks good now, & since it's only a vertical adjustment, I can't figure why the hole alignment is off.
Previous owner had the motor mounts directly bolted to the frame & cut a large radial groove into the center link...I also noticed he had the passenger motor mount loose!?! which might mean he has alignment issues as well.
Thanks for the reply!
Old 01-01-2013, 10:50 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I just got mine mounted back up.
I also used 1/2" spacers.
I plan on putting washers under the nuts, I just have them lightly tightened for now.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
350 engine, 62 chevy sedan, engine swap
