Old 12-10-2011, 08:31 PM   #1
Arl37
Is my oil pressure Low?
1972 307 in 69 C10. See below pics. Low reading is at idle when warm. High reading is driving at normal highway speeds. I have read that hash marks on gauge are for O-15-30-45-60 psi. If that is correct then I idle at 5 or 6 psi and at about 30 on freeway. Is this low or normal for a high mileage engine?Name:  IMG_0429.jpg
Size:  47.6 KB Runs smooth no knocks. Thinking of rebuliding before I paint but why do it if engine is Ok?
Arl37 is offline   Reply With Quote
Old 12-10-2011, 08:40 PM   #2
hjewell2
hjewell2's Avatar
Re: Is my oil pressure Low?
Originally Posted by Arl37 View Post
1972 307 in 69 C10. See below pics. Low reading is at idle when warm. High reading is driving at normal highway speeds. I have read that hash marks on gauge are for O-15-30-45-60 psi. If that is correct then I idle at 5 or 6 psi and at about 30 on freeway. Is this low or normal for a high mileage engine?Attachment 840084
Attachment 840085 Runs smooth no knocks. Thinking of rebuliding before I paint but why do it if engine is Ok?
If it was mine I would hook up another oil gauge that has # readings and compare the two.
hjewell2 is offline   Reply With Quote
Old 12-10-2011, 08:51 PM   #3
wyo tim
wyo tim's Avatar
As a rule you need 10psi for every 1000rpm for a stock small block chevy.
72 Chevy K20 NV 4500 /dana 60 /gm 14bt
72 GMC K10 Super Custom
84 GMC K35 SRW 454 t400/205
03 Ram 2500 w/Cummins
wyo tim is offline   Reply With Quote
Old 12-11-2011, 07:43 AM   #4
cdowns
cdowns's Avatar
i'd say that is very normal for a high milage smallblock chevy engine and nothing to b overly concerned about
it might slightly raise pressure if you run a 20/50 oil
Old 12-11-2011, 09:31 AM   #5
redbaron69
redbaron69's Avatar
x2 on cdowns comment.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 12-11-2011, 10:52 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that looks like a tired and worn out motor.
She could last 'X' more years... or days.
Old 12-11-2011, 11:45 AM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Couple of questions: Is the guage a 60 or 80 psi type. Do you have a high volume oil pump? What grade oil are you running?
If its a 80 psi, that looks fairly normal after the oil has been ran awhile. If its a 60 psi, its a little low if idleing at 0800 rpms.
A high volume will increse the oil pressue on a mechanical guage.
Oil vicosity also has effect on pressue. In the past, 10-30W runs about that range after warmed up. I run straight 30w here in FL and it stays higher on a 60 psi guage.
I would run it until you get all symptoms to rebuild or replace. ie: fouled plugs, exhaust smoke, noise power and low compression when checked.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
