![]() Join Date: Apr 2010
FREE Left over parts
I have some parts I took off of the truck and some used parts I bought and am not going to use now. All of the parts are free. I will not ship. Located 10 miles south of Buffalo NY.
72 stock disc brake set up. Spindles, rotors and calipers. You would need to probably put new rotors and calipers. Bought these before I decided to go with drop spindles. 67 original spindles. Front and rear stock coil springs. Stock pan bar. |
![]() Join Date: Jun 2011
Re: FREE Left over parts
I'll take the brake stuff if you will ship.
Just reread the add, thanks anyways. |
![]() Join Date: Nov 2011
Interested in the Disc brake set up- just bought my first Chevy truck so please be patient with me- will your 72 set up work on my 1970 Stepside? and what else would I need to convert my 6 lug drum brakes to disc- (preferably power disc)... Thanks in advance--
This link will tell you about converting to disc brakes. After you read it let me know if you want the parts. If you plan on doing a drop to the front end I can tell you where I got parts to do mine. I am doing a 4" drop i n the front and 6" drop in the back.
http://67-72chevytrucks.com/vboard/s...68&postcount=4 |
Wow... first thanks for the information.. I read the link you gave me and I'm afraid I just ended up slightly confused... My truck is a 1970 with 6 lug drum brakes- I assume that means it has the OEM cross member.
So am I correct in saying that your spindles, rotors, and calipers (from a 72 ) would bolt up without modification and that all I would have to doto convert to front discs is change out my ball joints? Sorry- this project is bumping up against my limited capabilities.. I live just East of Rochester so I'm close to you- I'm hoping this ends up a simple conversion.... please let me know your thoughts PS. What mod -if any - would I need to do to the rear 6 lug drums? |
Yes you would have to get 72 ball joints, outer tie rod ends. The rotors and calipers are rusty on the ones I have so you would have to get new rotors and calipers. As far as converting the rear you can do a search on the board here and there are plenty of articles.
![]() Join Date: Sep 2007
interested in the front springs if you are willing to ship. lemme know
1967custom |
sent you a pm re: pick up of brake stuff-
Wayne- good talking to you- gave me good advice- I'll pass on the brake stuff and let someone else benefit from your generosity.. Thanks again- Phil
