12-11-2011, 09:08 PM | #1 |
64 SWB Brake line question
I installed a disc/disc set up on my 64 swb. New prop valve, master, and booster have been installed. I got new brake lines (pre-flared) and they are 3/16" line where the orginals where 1/4" lines.
Is this alirght or should I switch to 1/4"? Thanks for you help! I should probably add some pics sometime. New engine gets here this week! |
12-11-2011, 10:53 PM | #2 |
60-66 Nut
Re: 64 SWB Brake line question
If you're talking about the front lines, 3/16" is fine for the front discs.
12-12-2011, 01:26 AM | #3 | |
I will get back to you on those engine mounts this week. I didn't make it to the junk yard today. |
12-13-2011, 12:54 AM | #4 |
60-66 Nut
I believe the line that goes to the rear brakes is 1/4" from up front, back to the hose that drops down to the rear end. Then it tees off with 3/16" to each side. If you can, I would run 1/4" from your proportioning valve to the line on the passenger side frame rail that goes to the rear.
