12-12-2011, 12:49 AM | #1 |
Junior Member
Bed too high? What did I do wrong?
I just assembled my bed for the first time and the bed does not line up with the cab. It appears to me the bed is about 1” too high. Where did I go wrong?
Details: I am assembling factory SWB fleet sides with the rest of the bed components coming from a long bed. Installed new poly cab mounts that appear to be correct – the front sheet metal looks right. Blue tape at body lines for reference. Pix:
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
12-12-2011, 01:09 AM | #2 |
The Older Generation
Re: Bed too high? What did I do wrong?
Did you use pads between the bed and the bed mounting brackets? LockDoc
12-12-2011, 01:11 AM | #3 |
Junior Member
No pads. Metal on metal.
12-12-2011, 01:17 AM | #4 |
OK. I think your tape is a little misleading. You should use the body line back toward the door for lining it up, not the end of the tape. Have the cab corners been replaced? LockDoc
12-12-2011, 01:24 AM | #5 |
i dont know but,, does the chrome on the back of the cab line up with the top of bed?
72 swb pickup http://i124.photobucket.com/albums/p...k/100_0958.jpg 1967 chevelle ss 1966 mustang getting a l33 ls motor 1969 chevy dump truck 1989 mustang 6.0 ls best time of 1.29 at 5.91 https://www.youtube.com/watch?v=JtbooZoGZmQ |
12-12-2011, 02:19 PM | #6 |
20' Daredevil (Ret)
Mine's about 1 1/2" from top of the bed to bottom of the chrome strip.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-12-2011, 01:36 AM | #7 |
Junior Member
old cab mounts?
frontstreetcycle on Instagram |
12-12-2011, 01:44 AM | #8 |
Metal vs wood box floors?
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
12-12-2011, 01:46 AM | #9 |
If I were a betting man, I'd say the rear bed mount on the passenger side is too low (or needs a spacer - or pad, etc).
All of them need a pad - metal on metal not good. But unless it's currently perfectly level side to side (ref Windmill's email) then I'm guessing adding a little spacer (or slightly thicker spacer than the rest) in the passenger side rear mount would help the height problem and fix the vertical gap problem (it is big at the top and tight at the bottom, indicating the rear of the bed is too low or the fron of the bed is too high). I'd look at the fwd drivers side mount and make sure it's not bent (up) somehow. Looks ok in the pic (if that's it) except for the missing pad. Could monkey with the rubber mounting spacers for the cab, but raising the cab to align would exacerbate the vertical gap problem, so I'd try to approach it from the bed if possible. |
12-12-2011, 03:14 AM | #10 |
Junior Member
Hey guys thanks for all the replys late on a Sunday!!
More pix:
12-12-2011, 03:27 AM | #11 | |||
Junior Member
Replaced those and I think I got it right? I did a forum search and read they were different heights. These all measure about 2-1/4". Came off the LWB donor that was an original wood floor truck and I'm sure never apart. Quote:
Yes gap seems tight at the bottom and bigger at the top. I'd prefer not to raise the cab unless I made a mistake installing the new cab bushings.
12-12-2011, 03:35 AM | #12 |
What cross braces are you using? I can't tell from the pics, but I went out and measured mine.
My stepside with a wood bed has 2-1/8" thick cross braces, and the steel fleetside bed floor I have has a hair over 3" thick cross braces. If you say you're about an inch high... it makes sense to me that you may have used the fleetside bed mounts? If you swap from a steel to a wood floor you need to use cross braces for the wood bed, the front bed panel is different, and even the "roll pan" looking piece that finishes off the back of the bed has to be unbolted, cut out, and swapped. EDIT: You posted while I was typing mine out and missed your last post. That answers that, should be the right ones.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-12-2011, 03:50 AM | #13 | |
Junior Member
12-12-2011, 05:04 AM | #14 |
is the bed side where it meets the wood floor bracket correct.. it being over the wood..
if it was on the underside of the wood it drop the sides 3/4" and fix some of that tight gap.. I haven't seen a wood bed so I might be way off base.. |
12-12-2011, 06:00 AM | #15 |
Scrapper 1
the guy with the 1964--66 chevy truck is right you don't want to run metal on metal every time you hit a bump it will make noise and bang I've uses the square rubber cushions on the under bed tabs trust me every your bolt loosen up you will hate the sound
12-12-2011, 06:21 AM | #16 |
I dun gradjiated collij!!!
Found this statement: "Wood bottom bed strips are different than the steel bottom ones are. The height is different and the way they mount are different. The tall wood bottom sills are 2 3/8" tall, and the tall steel bottom ones are 3 1/4" tall. WES www.ClassicHeartbeat.com" in this thread..... http://67-72chevytrucks.com/vboard/s...d.php?p=627553
Hope it helps you out.... Bill
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
12-12-2011, 08:12 AM | #17 | |
This is a factory short bed frame? If it's a shortened C/20 the rear cab mounts on frame are lower and require a different cushion.
12-12-2011, 08:29 AM | #18 |
That's what I get for answering tech questions during a 12 hour graveyard shift LOL
12-12-2011, 09:12 AM | #19 |
when you were down to a bare naked frame did you measure the frame to see if it was straight after 40years of use
12-12-2011, 09:55 AM | #20 |
In the first photo, it looks like the rear of the bed may be a little low. If so, it would make the front high and the gap near the cab corner and bed would be narrow while the gap near the top of the bed and the rear of the cab wider. Hard to tell from photos.
12-12-2011, 11:07 AM | #21 |
Dude ive seen alot, im aen alot of this, shim the cab
12-12-2011, 11:30 AM | #22 |
Got big-block?
cab bushings
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
12-12-2011, 12:25 PM | #23 |
The "rear" of the bed needs to come up 1/4" and then shim up the rear cab mounts to make it match....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-12-2011 at 12:43 PM. |
12-12-2011, 12:34 PM | #24 |
trucks72
Shim your cab up. Some of the new bushing you buy are not the same as GM. They are a litle thinner. Not all of them are this way but some. You will need to shim front and back some to get the gap of the cab and bed the same. As for the rubber on the under the bed. If you do that go as thin as possible. GM never did that from the factory.
12-12-2011, 03:27 PM | #25 | |
