Old 12-12-2011, 09:05 PM   #1
66_c10_tpi
Power Window Wiring
How have you ran your wiring from the doors to the cab?
66_c10_tpi is offline   Reply With Quote
Old 12-14-2011, 09:47 PM   #2
66_c10_tpi
Re: Power Window Wiring
Maybe I need to be a little more specific. I have the nu-relics kit. They supplied me with the S style of rubber conduits. They told me to mount one end to the outside of the post on the cab. But for me to do this I will have to put the conduit in quite a bit of a twist to attach to the door. I am trying to get an idea of what others have done.
Old 12-15-2011, 11:19 AM   #3
Clyde65
Clyde65's Avatar
I didnt do the chases when I had my PW's in, I didnt like them, although they weren't what you have, NuRelic are supposed to be real nice.
Anyway, mine I drilled into the door and as close as possible I drilled right accross into the jam ( dont know what that is called) then I had to drill again in the upper kick panel to bring the wires out, big pain because it is all blind and I had to fish the wires through.
I would love to see how you have them in when you get a chance, pix please?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-15-2011, 02:22 PM   #4
jimmydean
jimmydean's Avatar
Look how it's done on a newer car to get an idea. You can run the wires about anywhere in the jam, just make sure it doesn't bind. I have done straight shots as well as off-set.when that conduit is installed correctly, the wires are protected and move very little.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-23-2011, 12:17 PM   #5
64shortbox
64shortbox's Avatar
Here's what I plan on doing. I picked up a couple of boots from a square body Bronco, not sure of the year but sure looks like they will do the trick. The ends are 2" on one end and 1-1/2" at the other. The 2" end will go on the OUTSIDE of the door jamb (door will have to come off to drill the hole) The 1-1/2" end will go in the door.
64shortbox is offline   Reply With Quote
