Old 12-13-2011, 06:26 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Source for Turnkey LS GENIII 5.3L and 6.0L
I found a source for 5.3L and 6.0L engines. He's over on Pirate4x and seems to have some good feedback... I havent purchased yet but I think this is the route I'll be going in the spring.... 4 wire hookup and you're ready to go... he doesn't deal in transmissioins though...
Here's his info... LINK
BD TURNKEY ENGINES are GM GENIII Engines that are obtained from wrecking yards primarily from California. They are 5.3L & 6.0L engines from trucks & suv’s. I stipulate they must be clean, free of unusual corrosion, and have no more than 100,000 miles. These are the “cream of the crop” of junkyard engines.
The 5.3L & 6.0L GM engines are great engines for modern aftermarket projects. The 5.3L produces a legitimate 300hp, and the 6.0L, 325hp in stock form. With a good tune that I provide, these numbers go to around 325hp and 350hp respectably. With the addition of the Z06 / LS6 camshaft it is estimated that it pushes the 5.3L to 350+hp, and the 6.0L to 375+hp. These horsepower ratings are honest, naturally aspirated, and most importantly, RELIABLE – and AFFORDABLE!
PRICES - OCTOBER, 2011
COMPLETE TURNKEY ENGINES
60-100k miles
5.3L LM7 -------------------$1995.00
5.3L LM7 w/ Z06 Cam ------ $2600.00
6.0L LQ4 ------------------- $2800.00
6.0L LQ4 w/Z06 Cam ------- $3400.00
6.0L LQ9 ------------------- $3800.00
Engines with 40-60k = +$350
Engines with less than 40k = +$700
Every engine is VIN verified via CarFax, compression tested, placed on a run-stand, and brought up to full temperature. All sensors are checked for proper function, as well as general engine performance. I do not dyno run engines. I encourage anyone interested in my engines to come by and see and hear the engine run for your self. It is very satisfying to know you are truly getting what you pay for, a TURNKEY ENGINE!
Rich
1972 K5 Blazer CST Click HERE
Old 12-13-2011, 09:38 AM   #2
Shon
Re: Source for Turnkey LS GENIII 5.3L and 6.0L
HOLY CRAP.
we buy complete 5.3s (harness, PCM, accessories, starter, etc) for no more than $900 here and 6.0s are $1200ish.
Mail order tunes are $150-$250.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-13-2011, 09:57 AM   #3
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
$$$$$ wow. I'll keep my complete, running, all accessories, harness, pcm 5.3 with 70k for $550. And $600 for a simple Z06 cam install, likely with stock springs...with the engine out of the vehicle?
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 09-16-2012, 08:21 PM   #4
JCampbell
Where are you guys getting these engines?
JCampbell is offline   Reply With Quote
Old 09-17-2012, 01:19 AM   #5
Jdubs71
Jdubs71's Avatar
I thought I got a decent buy on a 05 5.3 under 40 k for $700 no tranny or ecm though. Keep searching craigslist for guys parting out wrecked trucks and ebay sells a lot as well. People are usually asking too much for them, but you can talk them down.
Jdubs71 is offline   Reply With Quote
Old 09-17-2012, 10:02 PM   #6
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I think he is offering harness and all or did I read it wrong?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 09-18-2012, 01:30 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I guess for the "Crate motor type" of guy this would work, but damn you pay for it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-18-2012, 03:40 PM   #8
ch0psv1lle
Any source for any lq4/9 blocks/cores?...... i want to build a 408 stroker with a carb and distributor.
ch0psv1lle is offline   Reply With Quote
Old 03-25-2013, 04:35 PM   #9
truckdude239
truckdude239's Avatar
Anyone use this guy?i was looking at his stuff?
it comes with Your BD Turnkey Engines come with the following:
Engine (of course!)
Engine Harness w/OBDII Port (modified OEM for minimum 3 wire hookup to run)
ECM (tuned to your specifications)
Gas Pedal Assembly & TAC Module (if DBW)
Intake Manifold
Oil Pan (generally truck style)
IAT Sensor
Fuel Rail - (5/16 & 3/8 hose easily adapts)
Throttle Body (DBC or DBW)
Throttle Cable, factory OEM style if applicable
All necessary sensors for turnkey application
Flexplate
Starter
Exhaust Manifolds, with connecting pipe to O2’s
Spark Plugs, Wires, & Coil Packs
Water Pump
Alternator & bracket
Air Conditioning Compressor, Bracket, Belt, & Port Blocks
Power Steering Pump & Bracket
Idler Pulley
Serpentine Belt
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-26-2013, 11:50 PM   #10
solidaxel
solidaxel's Avatar
My son put a Turnkey in his long travel sand car, and used it hard and it worked great
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-27-2013, 08:25 AM   #11
Clyde65
Clyde65's Avatar
Those prices arent bad when you look here. BTW, these have everything but the tranny! PCM, Harness
These are some built engines and from what I have been told are well worth the investment, but far out of my reach.
http://www.turnkeyenginesupply.com/c...treet-Engines/
I bought my fuel system from them also. high dollar but I have had no issues and it is alot quieter than most.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-27-2013, 08:28 AM   #12
truckdude239
My local yard is going to get me engine trans and harness And e m And the pedal for 1600
David fuller
2000 Tahoe 5.3l 378
Old 03-27-2013, 09:18 AM   #13
Jon01
Jon01's Avatar
Yeah, that guy is making good $ on those engines. But, he has to get them nut and bolt complete which is tough to do. Most yards are big fans of cutting and hacking things apart vs. unplugging connectors.
Jon01 is offline   Reply With Quote
