Old 12-14-2011, 07:42 PM   #1
C15_Sierra
C15_Sierra's Avatar
Oxygen sensor wiring
The yard I bought my engine from cut off the connector for the upstream, pass. side O2 sensor.
I got the part number from this page, 2/3 way down (http://chevythunder.com/ls1_page_1.htm) and ordered the connector and (what turned out to be the wrong) terminals from Mouser. I've got some female terminals from the connectors that I pulled from the harness, and look to be the right ones, but they don't fit. I'm at a dead end, anyone have any insight?
Local boneyards have been no help, they apparently cannot sell emission components, including the connector going to the O2 sensor
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 12-14-2011, 09:21 PM   #2
C15_Sierra
C15_Sierra's Avatar
Re: Oxygen sensor wiring
Found the right connector...took looking thru a bunch of the old ones I had to find the right VARIATION of terminal (apparently there are a couple similar ones that won't fit each others type of connector) and then found most of the right colors that corresponded to the pinout...right on...
-Steve
Old 12-15-2011, 12:03 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
you can get a wiring diagram and the generic bosch pigtail, with the matching sensor pretty easily. Many aftermarket harnesses use this setup instead of the more expensive oem parts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-15-2011, 08:09 AM   #4
C15_Sierra
C15_Sierra's Avatar
I thought that might be the case, because I found pigtails for most everything else that was missing in my harness, except for the right O2 sensor pigtail (they have the square ones, I needed the flat one)...the connector I bought was only $1.60
-Steve
Old 12-15-2011, 01:39 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
do you have all the 02 sensors already tho? The oe sensor is almost double the price of other suitable units.
