Old 12-15-2011, 12:38 PM   #1
matthew.mcmullin
My 72 is dead...
So I took my 12 year old son out into the orchard to let him have a little fun trying to drive the truck around. It was his first time driving a standard. We were having a ball until he had to stop and forgot to push in the clutch.
When we went to start it again it was dead.... No power anywhere. Hooked up the jumper cables and still nothing.
Any ideas on where I should start?
matthew.mcmullin is offline   Reply With Quote
Old 12-15-2011, 01:05 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: My 72 is dead...
Check the cables from the battery...if you're not getting power anywhere, I would think something came loose or is severly corroded.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-15-2011, 01:09 PM   #3
hugger6933
X2 check the grounds and are'nt you waiting a little long to let your son drive? He is 12 after all. Great times I miss them a lot with my kids
hugger6933 is offline   Reply With Quote
Old 12-15-2011, 01:10 PM   #4
mr48chev
mr48chev's Avatar
Check those and check the wire that goes from the junction stud by the battery across the core support and around into the cab. There is a fuseable link or should be one right close to the battery and that may have blown or battery acid may have eaten the connection on it like it did on mine a while back.
If you have a good test light test across the battery posts to make sure the battery is charged. Then check from the + post to a good ground on the engine to see if you have a circuit there. keep testing until you find where the power stops. It may just be a loose cable as TubbedII said as quite often they will jar loose.
A volt meter can tell you if you have a big voltage drop in the line due to a resistance like corroded terminals or a corroded connection too.
Old 12-15-2011, 03:58 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i was going WOT throttle bounching thru the field a few years ago in my grandmaws original 53 chevy, broke the taililight and learned to shift 3spd
Id start with grounds to
John
1999 Toyota Tacoma 4x4
Old 12-15-2011, 05:24 PM   #6
matthew.mcmullin
He's driven before but only the automatic. This was his first real test. I'll check the grounds and stuff.
Old 12-15-2011, 06:05 PM   #7
domeier
domeier's Avatar
Orchards are full of trees. You are a BRAVE man!
domeier is offline   Reply With Quote
Old 12-15-2011, 06:11 PM   #8
CC69Rat
CC69Rat's Avatar
Regardless -- let him help you fix it if you know what I mean.
X4 (?) on the ground situation .. were you guys bouncing around pretty good? When you hit the starter it won't even grunt? Dead cell in the battery maybe? Maybe pull the battery and take it by Autozone (or similar) and have them check it for you.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-15-2011, 07:42 PM   #9
Lee H
Lee H's Avatar
Also check the main harness connection at the fire wall.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-19-2011, 12:00 PM   #10
matthew.mcmullin
Thanks for the suggestions... There was a fuseable link on a small wire from the battery that must feed the main power to the fuse box. My son paid the $4.00 to replace it and now we can go give it another shot. He wasn't going fast enough to hit any trees but he certainly likes to talk about it.
Old 12-19-2011, 12:33 PM   #11
domeier
domeier's Avatar
I had a battery cable corrode completely through inside the clamp. It was the type shown below, where you can't see the cable-to-terminal connection. Give your cables a good tug and see if one of 'em doesn't come apart.
