12-16-2011, 04:32 PM | #1 |
Rear broken shock mount
Anyone ever experience a broken rear upper shock mount? I was adjusting my rear brakes today and noticed. I will have to get it welded.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
12-16-2011, 06:48 PM | #2 |
Re: Rear broken shock mount
Pretty common problem on these old trucks. I have made a plate and used a couple of big washers to fix it temporarily until I could weld it up.
12-16-2011, 07:30 PM | #3 |
It's best to reinforce them when this happens. beat the crack straight, weld the gap then weld on a plate and mount your shocks on it.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
12-16-2011, 10:24 PM | #4 |
Drill the end of the crack to stop if from going any further too.
12-17-2011, 02:53 AM | #5 |
Does it look anything like this lol Im going to drill the end of the crack, and plate it. My truck will be bagged so I wont be using the stock shock location anyways.
12-17-2011, 03:52 AM | #6 |
Still plays with trucks
They really should have made the upper rear shock mount a double shear design. Every one of them I have ever seen has been wallowed out or torn up. Just too much pounding for a single mount point stud.
I'm going to fab up a secondary bracket for mine and convert it to a through bolt design.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-18-2011, 08:34 PM | #7 |
kunzy420..... looks EXACTLY like that lol... Thanks for the info guys. I agree it's a pretty lame design IMO
12-21-2011, 11:40 PM | #8 |
Does anyone know a part number for the stud that goes through the frame where the shock bolts to? I ended up having to cut mine since the backside nut was completed corroded to the stud. Hopefully these are still available to purchase.
12-22-2011, 12:41 AM | #9 |
12-22-2011, 12:43 AM | #10 |
If you cant get the studs, Ill check my shocks to see if mine are still attached/useable..and send them to you. like I said if you cant find any or fab anything up.
12-23-2011, 12:19 AM | #11 |
Pretty much any auto parts store that sells shocks will have them or can get them.
