12-17-2011, 09:17 PM | #1 |
Engine block paint
I am building a 350 and I need to know what brand and/or type of paint to use to paint the block. I am going to leave the heads steel - for contrast. I used the "high heat" (crap) last time and it cooked off within the first ten minutes (and the smell was horrific). What are you guys using? Thanks.
Sam |
12-17-2011, 09:33 PM | #2 |
Re: Engine block paint
The best I've found is from POR-15, it's a little on the pricey side but looks good and stays on.
Rick 69 SWB Project 95 Suburban Daily Driver 47 Flxible Motor Home 427 GMC 4spd Allison 71 C-10 LWB 307/350 (parted out) 64 SWB Custom Cab 283 powerglide (sold) 2000 Yamaha Venture |
12-17-2011, 09:47 PM | #3 |
/\/\ WOW, that thing looks GOOD!!! Is that the POR 15?
12-17-2011, 10:01 PM | #4 |
Thanks, Yes it is, even on the exhaust manifolds.
12-17-2011, 10:34 PM | #5 |
I am fond of the VHT brand "new cast grey" engine paint.
12-17-2011, 10:51 PM | #6 |
BlackedOut, Where would i locate that? It would be cool to have the steel look, WITHOUT the rust!!
12-17-2011, 11:49 PM | #7 |
Most larger parts houses should carry it....
Dupli-color # DE1651 VHT # SP997 |
12-17-2011, 11:51 PM | #8 |
x2 on the vht
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
12-18-2011, 10:45 AM | #9 |
The biggest issue is to get all grease and solvents off of the block / heads before any paint is applied, last motor I did never used primer on it, the rough casting holds the paint well. This was stainless steel equipment paint, still looks good today only a light color change to a little darker which I did`nt know would happen but actually looks better.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
12-18-2011, 12:30 PM | #10 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
12-18-2011, 12:54 PM | #11 |
if the engine is not assembled yet you can powder coat the block and ceramic coat the exhaust. it looks amazing.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
12-18-2011, 02:07 PM | #12 |
give me some time darkhorse, its buried in my shed, its industrial paint. But i will find it.
12-18-2011, 02:28 PM | #13 |
Darkhorse here ya go .. http://www.steel-it.com/ I used the polyurethane
http://www.steel-it.com/products.htm they also sell it in Epoxy After read inng the label its much like por 15 , its has a rust preventer in it.
