Old 12-18-2011, 03:50 PM   #1
todddesignr
1963 GMC 305 Harmonic Balancer
I am attempting to source a new harmonic balancer for my 305 V6. I've read through past forums and have run into dead links for $30 replacements to Summit Racing, yet when you put in: 1963 GMC 1500 5.0....etc, it comes up with nothing. I just recently purchased this vehicle and after giving it a going-over discovered some wobble in the balancer. Does anyone have a good listing for a replacement, the only ones I've found are at LMC truck and they run from $180 and $400....not hapening. Thanks in advance
Todd
1963 GMC 1500 Fleetside
5.0/305
Ogden, UT
todddesignr is offline   Reply With Quote
Old 12-18-2011, 05:00 PM   #2
creep
Registered Loser
creep's Avatar
Re: 1963 GMC 305 Harmonic Balancer
Try rockauto.com
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 12-18-2011, 07:53 PM   #3
maxwoof
Google Dale Mfg. Guy rebuilds them. He did mine, quick turnaround, good work.
maxwoof is offline   Reply With Quote
Old 12-18-2011, 09:34 PM   #4
MusicMan70
MusicMan70's Avatar
Hey Todd,
your 305 does not have a harmonic balancer. It's more of a flange that the pulley bolts to as well as having some markings for timing. This engine is internally balanced.
Perhaps you just have some or one bolt(s) loose down there...
If the flange is damaged you may have to go junkyard or the parts for sale on this site... Hope this helps, Henry
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-18-2011, 09:43 PM   #5
MusicMan70
MusicMan70's Avatar
Forgot to also mention; a lot of Great info on these unique engines at this site as well.
Welcome and Congratulations on your new Truck!
http://www.6066gmcguy.org/
MusicMan70
1961 GMC Suburban
Old 12-18-2011, 10:10 PM   #6
HEI451
Mine's like in the pictures. It doesn't have any elastomer, is one piece, NOT two piece. When I got my engine, it had the front hub broken, in that the former person that had it, jammed the damper onto the crank with the key not in the groove in the rear, literally peeling up the seal area by the key in the crank being stuck up out of the groove. This took all the rubber out of the front seal, causing a massive il leak.
I fixed the hub by spinning it on my lathe, cutting the seal area down and further to the front of the hub, then, cutting a short section of thick muffler tubing to interference fit the undersize cut hub. After sealing and pressing the tubing onto the hub, I trhen cut the tubeing to the same size as the hub had for the seal. I then installed the key into the crank all the way, and reinstalled the hub. It works fine.
Since this isn't a two piece damper, only a one piece hub, it can be repaired. Welding/machining is one possibility, as is any other operation to repair it. Just where is it "wobbling"?
HEI451 is offline   Reply With Quote
Old 12-19-2011, 04:29 AM   #7
NorthstarGMC
Todd,
My 305 didn't have a dampener on it. Maybe you could take a picture of the broken part?
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 12-19-2011, 02:53 PM   #8
todddesignr
Thank you one and all for your insight. I'll take some pictures when I get home tonight and post them in an effort to solve this riddle.
Old 12-19-2011, 09:25 PM   #9
todddesignr
I took a couple of pics before it got dark and as you so aptly described, it does not have a harmonic balancer. I see that I need a new belt and I may have a bolt or two missing (too cold and dark right now to mess with it). During a revolution, as I watch the timing indication needle, the pulley appears to be about a 1/4 inch out of round.
Old 12-19-2011, 10:52 PM   #10
MusicMan70
MusicMan70's Avatar
Todd, the pulley appears to be bent...maybe somewhere in it's past it ran over something and just wacked it good enough to cause a permanent wobble. When you do get it off you may to re-wack to bring it into compliance.
MusicMan70
1961 GMC Suburban
