12-19-2011, 09:53 PM | #1 |
1981 tach cluster with trip odo
I pulled a tach cluster from a 1981 C30 yesterday at a local LKQ U-Pull-It and later I noticed it has a trip odometer. I pay close attention to tach clusters (I seem to have a fetish for them, this is my third 1980+ tach and my second found in a self serve yard in less than 6 months.) but this is the first one I've ever seen that's original - the truck had the correct tach cluster RPO on the SPID label - that had the trip odo. I watch them on ebay all the time and again, I've never seen one with a trip odo.
What years were the trip odo available? (besides 1990-91 with the electric speedo) Truck had delay wipers, tach and little else. I also grabbed the working delay wiper pieces for my truck.
Jay 2001 Pontiac Aztek GT |
12-19-2011, 11:28 PM | #2 |
Moderator
Re: 1981 tach cluster with trip odo
I'v only seen them on the 87+ R/V trucks. I'll look in my parts books later this week.
12-20-2011, 11:57 AM | #3 |
gosh y cant i find one good find thow
Edited by staff |
12-20-2011, 06:21 PM | #4 | |
I wonder if this truck had it's original tach cluster replaced with a later tach cluster (which also had a trip odo). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-20-2011, 11:43 PM | #5 | |
Here it is when i got it home. Here it is after I restored it with new needles and lens. It came from a manual trans truck and I added the OD gear selector. I also added the numbered temp gauge, before it had the C-H gauge. Not sure when GM switched over on that either. Here's the back. Now, I've noticed newer clusters have the cable clip attached to the speedo and this one has the cable clip attached at the housing. My other tach cluster that's in my truck now has the clip attached at the speedo and my original 1981 speedo would not fit due to this. I pulled it from a 1986 C3500 GMC. It does not have the trip odo. I'm wondering what year the trip odo was first available, since my 1981 speedo didn't fit in my 1986 cluster and this one doesn't fit either. Also, this cluster's fuel gauge has just a gas pump on it. The other says "unleaded fuel only" I'm assuming this has to do with it being from a 1 ton truck and the other being from a 1986 truck. This is the 1986 cluster that is now residing in my 1981 truck. It didn't have the trip odo lens, the original was super dirty and I replaced it with one from a 1991 cluster i grabbed because I eventually want to build a tach cluster with an electric speedo.
Jay 2001 Pontiac Aztek GT Last edited by c10sport; 12-21-2011 at 12:02 AM. |
12-21-2011, 01:06 AM | #6 |
78K & 79C Jimmys
my 87 Canadian burb had the trip od,but no tach
and the 88 American burb had a trip od, no tach and yup noticed the speedo clip thing switching or trying to switch late 80's to 79
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-14-2017, 09:28 PM | #7 |
What's up with post #6..or is it just me
12-14-2017, 10:21 PM | #8 |
12-20-2011, 06:47 PM | #9 |
Slots go on anything!
I would bet that the speedo head had been changed. I am pretty sure the trip odo started in the 88 R/V trucks; all 88& 89 trucks would have had this, as well as 90 2wd trucks (with the speedo cable).
1974 Jimmy- 5.3/4L80e/NP241 |
12-21-2011, 12:55 AM | #10 |
The hole for the VSS signal looks off to me. I think the speedo was retrofitted. Just my thought.
12-21-2011, 01:00 AM | #11 |
I would agree with that as well, I have only seen the trip odometer in suburbans myself
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-23-2017, 04:06 PM | #12 |
1990- up sub, 1ton for sure if they had the option
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
12-23-2017, 06:00 PM | #13 |
90-91 were electric speedo for those who dont know .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
