12-21-2011, 10:57 AM | #1 |
Trouble removing U-Joints
I have a 1986 Chevy c-10 305 v8, The u joints appear to be held in by a pin driven all the way through to the other side. before I try to drive these pins out, I want to make sure that I am doing it correctly. The rear joint also has a dust cap cover holder that holds one side of the cross together. Does anyone have experience with this set up? Thanks Much Joe
12-21-2011, 11:01 AM | #2 |
Re: Trouble removing U-Joints
The "pin" is just plastic that was injected into the u-joint to keep it from coming apart. All you need to do is press the u-joint out, it will take a little more force to get it out but it should just shear the plastic.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
12-21-2011, 11:05 AM | #3 |
a little heat will melt that plastic pin then they come out easy or a small drill bit
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-21-2011, 11:12 AM | #4 |
Thanks much for the info. Have you seen the type of rear one that has a retaining clip on one side of the cross, apparently perhaps a saftey clip, to hold the caps on? Thanks again and merry christmas, This forum is the best!
12-21-2011, 11:24 AM | #5 |
Yup, pull tha clips, heat the end with a torch. That plastic will shoot out like its been extruded, and it stinks. Push out the caps quick while everything's hot. It'll come right out. Have fun!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-21-2011, 11:28 PM | #6 |
It is just like they said. i sought the experts here myself a few months ago. Thanks again.
12-21-2011, 11:43 PM | #7 |
Where was this post a few months ago lol, I figured it out after trying to punch out the "pin" Then it dawned on me! HEAT
12-21-2011, 11:50 PM | #8 |
GoatLube Experss
use cation while heat'n it up. sometimes it will shoot out and splatter, where glass's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
12-22-2011, 09:02 PM | #9 |
12-22-2011, 01:35 AM | #10 |
And don't forget how you did it. My '03 Trailblazer had the same plastic setup, you will more than likely run into it again.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
12-22-2011, 05:15 PM | #11 |
When you replace them you will have the option of a sealed one like you are replacing, or one that comes with a grease zert. The sealed ones should be a lifetime warrenty, and a few bucks more.
12-22-2011, 09:04 PM | #12 | |
it makes no sense because the grease ones are not as strong as the non grease |
12-23-2011, 09:58 PM | #13 |
All About the BOWTIE
Here's a thread from when I had to replace mine..with factory sealed units..
Hope this helps wow..it won't allow me to post the thread from another site..weird??? anyway...where the * is... it's suppose to be (g m s q u a r e b o d y . c o m).. then the rest of it..should take you to my thread http://www.gm***************/forum/s...ead.php?t=1290
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 12-23-2011 at 10:14 PM. |
