Old 12-22-2011, 10:33 PM   #1
medicman775
Power window stopped...need help quick
83 burb passenger side back door window stopped and need to get it closed....it's 22sold degrees out. Tried putting pressure with hands and pushing and grabbing from top. Any tricks to getting the window all the way up?
medicman775 is offline   Reply With Quote
Old 12-22-2011, 10:52 PM   #2
mullit
mullit's Avatar
Re: Power window stopped...need help quick
pull the door panel off and wack the motor with a hammer a couple times.
mullit is offline   Reply With Quote
Old 12-23-2011, 02:25 AM   #3
tobiahr
tobiahr's Avatar
make sure its the motor only...not the glass
you may want to cover the open window with a blanket of something to keep the heat in and warm the motor up a little. when really cold the grease can thicken up making the motor work harder and not be strong enough to move the window
tobiahr is offline   Reply With Quote
Old 12-23-2011, 06:52 PM   #4
mullit
mullit's Avatar
Old 12-24-2011, 04:40 PM   #5
medicman775
Turned out to be a wiring issue. Took off door panel and tried switch to see if anything obvious and it worked. Re-installed panel and still all works.
