Old 12-24-2011, 02:34 PM   #1
Holt
Help finding weatherstripping
Can anyone recommend a company or website to buy weatherstripping? Looking to replace the weatherstripping around the doors on my 67 c10, there are so many options on the internet i want to get a good set.
Holt is offline   Reply With Quote
Old 12-24-2011, 04:04 PM   #2
cadillacart
1972 C/20
cadillacart's Avatar
Re: Help finding weatherstripping
I've heard somewhere that ranger weather stripping works better than stock as it is press on?? I think I remember that it was from a Ranger, not 100% sure
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 12-24-2011, 04:26 PM   #3
blkcorvair
blkcorvair's Avatar
GMC Paul seems to have nice stuff. USA Made and lifetime gaurentee if I recall. Plus you can buy modern push on seals instead of the glue on if you prefer...
blkcorvair is offline   Reply With Quote
Old 12-25-2011, 01:05 AM   #4
leddzepp
Moderator
leddzepp's Avatar
These are the best, hands down. Just read the reviews here: http://67-72chevytrucks.com/vboard/s...d.php?t=438649
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-24-2011, 04:27 PM   #5
cadillacart
1972 C/20
I should add that I just installed new door weather stripping on one of my doors. I got everything from Early Classic and everything fits good, gluing sucks though :-)
My Gallery
1972 C/20 402
Gramp's Truck
Old 12-24-2011, 05:21 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have NOS, in the box, plus I also have aftermarket weatherstripping. I'm thinking the aftermarket will be fine for my use, but haven't yet decided to sell the NOS. Weighing my options......
Member Nr. 2770
Old 12-24-2011, 05:31 PM   #7
WAAF
steele made in s.c.
WAAF is offline   Reply With Quote
Old 12-24-2011, 05:31 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
heard dodge dakota fits good too
John
1999 Toyota Tacoma 4x4
Old 12-24-2011, 07:44 PM   #9
Holt
thnx for the replies!
Old 12-24-2011, 07:45 PM   #10
Dunenutt
Newbee
Dunenutt's Avatar
http://www.soffseal.com/store/main.aspx
Dunenutt is offline   Reply With Quote
Old 12-25-2011, 12:10 AM   #11
LockDoc
The Older Generation
LockDoc's Avatar
If you are really cheap like me you can go to the salvage yard and get 1987-97 Dodge Dakota slide on weatherstrips. You will need to take a philips screwdriver, small hammer, a small pry bar, and a pick tool for cleaning out the heads on the philips screws in the sill plate to get them off. You can usually get a nice pair for under 10 bucks... You have to cut about three inches off of them. Be sure to get the connector that joins them at the seam. Sometimes it falls out when you remove them.
Also be aware that when installing different weatherstripping the doors may be tight when closing them. If the doors are too tight the door locks probably won't work. There is too much of a bind on the latches and it won't allow the lock actuators to engage. If the doors are too tight try moving the striker plate out a bit. Be sure and mark around it with a fine felt tip marker first so you can tell how far you have moved it. Only go about 1/16" at a time and don't let it move up or down, just out. It shouldn't take much if that's the problem.
LockDoc
Leon
Old 12-25-2011, 01:15 AM   #12
cadillacart
1972 C/20
Dodge Dakota!! that's what I was thinking of
My Gallery
1972 C/20 402
Gramp's Truck
Old 12-25-2011, 01:21 AM   #13
redmonster
redmonster's Avatar
I used 2002 dodge dakota on mine they have a metal crimp
Inside best fit and 6 bucks for both at the junk yard
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 12-25-2011, 09:37 AM   #14
mbgmike
You can buy new dodge strips for under 20.00 each also. its actually the same for the larger trucks just shorter. On the 65 I just found the one that fits the best from a chain of product samples. I spent under 30.00 for two and they worked fine
mbgmike is offline   Reply With Quote
