Old 12-28-2011, 11:25 AM   #1
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Ole Blue's Makeover
Well the time is finally HERE!!!! YEEHAWWW!!!! I started the official rebuild of Ole Blue on 12/26/2011. Here he is when he found his new home Name:  Old wheels.jpg
The first thing on the agenda was the heart. Gotta have the fluid pumpin at all times & in good shape. Don't want any heart attacks, strokes etc.... Name:  Old_motor.jpg
Name:  rags draining.jpg
Name:  new rocker arms.jpg
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 12-28-2011, 11:35 AM   #2
Camaro_nut2001
Re: Ole Blue's Makeover
After gettin everything cleaned up, new cam, gears, pump etc... in I think his old heart was good as new
Size:  70.9 KB. Next was safety, lol. Gotta be able to move safely with the new heart, fast beatin heart. I just bandaged up the real bad scrapes to get him by till the major surgery Name:  bad_control_arm.jpg
Name:  control arm studs.jpg
Name:  new ball joint.jpg
Name:  old ball joint.jpg
Old 12-28-2011, 11:46 AM   #3
Camaro_nut2001
After gettin Ole Blue safe to start movin around I got him some new shoes
Name:  New_DSide_ wheels.jpg
Next, I had to get him lookin good for the women, lol. Soooo, time to move to the interior for now. Here he is before the small surgery
Name:  Old_steering_ wheel.jpg
Name:  old gauges.jpg
During surgery
Name:  column out inside.jpg
Name:  Old Column Out.jpg
Old 12-28-2011, 11:50 AM   #4
Camaro_nut2001
More...
Name:  dash wiring cleaned up.jpg
Name:  gauge panel wiring.jpg
Name:  Building gauge panel.jpg
Old 12-28-2011, 11:55 AM   #5
Camaro_nut2001
More....
Name:  new gauge panel.jpg
Name:  new steering wheel.jpg
Old 12-28-2011, 11:57 AM   #6
Camaro_nut2001
My best friends art work
Old 12-28-2011, 12:35 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im in this is gonna be great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-02-2012, 06:48 AM   #8
Camaro_nut2001
Got a little more done over the holidays ( I hope everybody had a Wonderful Christmas & New Year ). The front end is now completely rebuilt, new upper & lower control arms, ball joints etc... etc... My batteries went dead in my camera before I could get pictures of the finished front end but here are a few before it went dead. I am now running 3" drop springs & drop shocks
Old 01-02-2012, 06:57 AM   #9
Camaro_nut2001
Also got the rear finished up. Put new axles, bearings & races, all seals, Detroit Posi with Richmond 3.73 ring & pinion & 5" drop springs & drop shocks. We didn't have to move the shock brackets & like I said, my batteries went dead before I could get all the pictures I wanted to take.
Old 01-02-2012, 07:01 AM   #10
Camaro_nut2001
Got started on the cab & found this
Sooo, we'll be puttin new floor pans in next & I WILL have plenty of new batteries for my camera, lol. More pictures to come...
Old 01-03-2012, 02:41 AM   #11
bigblock68
bigblock68's Avatar
looking good....you're really flying on this!
bigblock68 is offline   Reply With Quote
Old 01-05-2012, 09:55 AM   #12
MONTE
MONTE's Avatar
Whats up with the rear wheels, they look nice. What size is that on wheel and tire? I need to upgrade mine with tubs.
MONTE is offline   Reply With Quote
Old 01-06-2012, 02:04 PM   #13
Camaro_nut2001
They are 15X12 with 7.5 backspacing, 5X5 lug pattern. The tires are Hoosier 31/16.5/15. All I had to do is cut one rib out of my bed & get two more wheel tubs to widen my two. Thank you for the compliment. I hope to have more pictures tomorrow.
Old 01-08-2012, 01:05 PM   #14
Camaro_nut2001
I went up to my buddy's that's doin Ole Blue & took a few pictures. He is movin right along. While I was there I had to get some " Hands On " time so I ran the wiring for the fuel pump, gauge & ran the 1/2" aluminum line. I also got the fuel filter mounted where the heater box used to be. My buddy didn't weld the holes up in case I ever wanted to put the heater assembly back on. He cut some polished aluminum & put over the holes so I could mount my filter & regulator. He also got my shifter console mocked up & I think it looks great!! He's gonna fiberglass over the wood, filler & gel coat smooth & paint it to match my interior color. Here is where we're at now.
Got the new bushings in & por15 painted on the frame under the cab & got the cab back on
He got the rocker panel moved down where it's suppose to be & just tacked in
Console mocked up
Fuel line & wiring ran
Old 01-08-2012, 01:18 PM   #15
northern 85
northern 85's Avatar
That is a Very cool truck you are building!
northern 85 is offline   Reply With Quote
Old 01-09-2012, 01:06 AM   #16
Camaro_nut2001
Thank you!!! I love my truck & also love this hobby. I just wish I was able to do more than I can but.... It is what it is.
Old 01-08-2012, 01:20 PM   #17
Camaro_nut2001
Got the cab floor coated with Por15
Started sandin on the cab
Wiring ran for my fuel gauge & pump. I'm runnin my fuel pump off a toggle switch mounted next to my electric fan switch
Fuel filter mounted on the firewall. I think when I get my regulator, return line etc... ran it'll look alot better. I'm goin with the 1/2" braided stainless line
Old 01-08-2012, 01:36 PM   #18
Camaro_nut2001
Almost forgot, we found out what number my truck was built!!!!!
Old 01-08-2012, 01:40 PM   #19
westgl
westgl's Avatar
Very Nice it's coming along.
I am going to need to do some of the work that you are doing.
keep up the good work
Westgl
westgl is offline   Reply With Quote
Old 02-12-2012, 02:26 PM   #20
6772owner
Gearhead
6772owner's Avatar
Looks like a lot of work! Great progress, those colors are going to be awesome!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 02-13-2012, 01:55 AM   #21
Camaro_nut2001
I don't know about it being alot of work but it sure is alot of fun, lol. This is all i've ever really enjoyed in my whole life as far as a hobby goes. I really liked the colors when I picked them out of the paint book but when I got to actually stir the paint up & look at it under a light I was amazed!! I hope it turns out as good as what i've got pictured in my head & we're givin it our best shot. All I know is, I will have this memory, or pictures of it anyway, lol, for the rest of my life. I have always wanted to build my own truck with my own hands for as long as I can remember & at 43yrs. old I'm doin it and doin the paint & body with my best friend. Without him I couldn't do it, I just don't have the knowledge when it comes to body work...but...I'm learnin & lovin every second of it! Thank you for your interest.
Old 02-13-2012, 06:45 PM   #22
6772owner
Gearhead
6772owner's Avatar
That is awesome buddy, this is a great hobby and a lot of fun when you get to make progress. I bet those colors really pop in the light... Glad you have a good friend to share it with, it always makes for great memories! Keep up the good work!
Old 02-13-2012, 07:34 PM   #23
67cheby
67cheby
67cheby's Avatar
Looking good !
67cheby is offline   Reply With Quote
Old 02-15-2012, 12:17 AM   #24
Camaro_nut2001
Originally Posted by 67cheby View Post
Looking good !
Thanks fellers!!!
Old 02-16-2012, 11:04 AM   #25
Camaro_nut2001
My buddy put the first coat of base on the door jambs & made the line where the two colors split yesterday. He's gonna put 4 coats of base & 5 coats of clear. You can't see the pearl in the base in the pictures but in person you sure can. I also got my new emblem for the hood & it looks very nice. So far I am very happy with Top Banana. Not only have they sold me top quality parts but have excellent customer service. They have emailed me tracking numbers, checked to make sure I had recieved the parts & that I was happy with them. Anyway, here's where we're at now & I think we're gonna hang the doors today if he got all the jammin done last night
