Old 04-23-2003, 07:21 PM   #1
western star
western star's Avatar
Bench seat question
I have a 1971 Chev truck and want to replace the buckets and console with a bench. Do I have to stay with a 67 to 72 bench or will the mid to late 70's seats bolt right in?
western star is offline   Reply With Quote
Old 04-23-2003, 07:36 PM   #2
Jwill41
Jwill41's Avatar
the late 80's early 90's split bench works very well.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 04-23-2003, 07:40 PM   #3
western star
Do they bolt right in?
Old 04-23-2003, 07:49 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Look here
This web page belongs to member palf70step. He can probably fill in the details for you.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-23-2003, 10:33 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just so no one rips you off...or even worse, so you don't throw them away, the buckets and console are worth quite a bit of coin.
Old 04-23-2003, 11:08 PM   #6
gr8scott51
gr8scott51's Avatar
I have a mid-90s Silverado bench in my 68. It does NOT bolt right in. But all I had to do was drill 4 holes in the flat area under the stock bench. It is a very comfortable seat, especially on long trips. The newer seats are solid foam - no springs - and therefor give much better support. Purists won't like my answer, but to each his own. Try different seats before you choose one.
The stock buckets and console are worth some bucks to someone doing a resto.
Good luck. Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 04-24-2003, 12:38 AM   #7
western star
Long horn mail thanks I do know the value of what I am taking out of the truck and they'll be tucked away in the basement for later. Right now I need the truck to seat myself and 2 blondes.
Old 04-24-2003, 02:15 AM   #8
Project1970
14.1 @ 96MPH
Project1970's Avatar
I've got a 1999 Suburban middle seat; had to drill most of the holes and cut on the stock brackets a little bit, but I think it's one of the best deals going - I got mine for $150. Part of the center seatback folds down to be the center console.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-24-2003, 08:50 AM   #9
griesel72
griesel72's Avatar
I have a 94 60/40 split bench seat in my 72, Had to drill holes, but the brackets almost fit perfect, had to build a spacer for the inside bracket of the passenger side 60 seat. They look really good, mainly because of the headrests.
good luck
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 04-24-2003, 08:53 AM   #10
dubie
dubie's Avatar
2 blondes eh??? is that your wife and your daughter heheh kidding!! I am going with a similar swap. I started out with a factory bench, then traded for a set of buckets, but never installed them. But now I stumbled across some seats from a 98 Dodge Ram that has the fold down console in the middle, so now I will be sticking with those
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-24-2003, 02:35 PM   #11
O'skool 72GMC
O'skool 72GMC's Avatar
seat for sale
I've got a 60/40 split bench seat for sale with the fold down middle armrest that you can put things in. grey in color and in perfect condition. it's the 95-99 style that doesn't have the seat belts built inot them.
O'skool 72GMC is offline   Reply With Quote
