12-29-2011, 11:26 PM | #1 |
seam sealer
Getting ready to put the seam sealer back in around the roof channel. Any tips or techniques from the professionals. It sounds easy but should I use some tape to get a clean edge. I have heard dipping your finger in paint thinner will help smooth it out as you go??
My build 64C10: http://67-72chevytrucks.com/vboard/s...d.php?t=439559
69 chevelle malibu, 64 C-10 shortbed |
12-30-2011, 01:05 AM | #2 |
Resistance is Futile
Re: seam sealer
I've heard of the thinner trick and used it many years ago;turned out well. Just did my '66 last year and gooped it in without caring too much and it turned out ok. Dont try to recoat without it drying, Ive found. Used a different type on my 'burb about a month ago and its sandable, so its easy to feather into the roof. It will also be covered with primer.
I've tried using latex gloves but the drip edge always cuts the gloves. It makes a nice bead, though. Generally, I would try to use plenty of product and clean up the mess to get the nicest looking surface. I had issues when it got too thin and I 'ran out' of sealer while sliding my finger through the groove. I'm not a professional, by the way.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-30-2011, 01:19 AM | #3 |
Re: seam sealer
Fuzor self leveling seam sealer is the best I've used for drip rail seams. Just prep it and apply it and it smooths itself out.
Here's a YouTube vid that shows the process. Posted via Mobile Device
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-30-2011, 02:03 AM | #4 |
Senior Enthusiast
Re: seam sealer
Here's a recent thread that shows the stuff (Evercoat Maxim) I used:
http://67-72chevytrucks.com/vboard/s...86#post5090786 |
12-31-2011, 10:43 AM | #5 |
Re: seam sealer
fuzor is the name brand I bought but I got the regular factory match stuff.
