12-31-2011, 11:08 AM | #1 |
Compressor pump?
Ok so my compressor decided to die on me the other day and I'm wondering if my 3.5 hp motor will run a larger pump? I woul really like more cfm's from my compressor but don't want to spend $1000 for a new one.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
12-31-2011, 11:37 AM | #2 |
Newbee
Re: Compressor pump?
Pumps are rated by horsepower. You can buy a 3.5 HP pump, and check the amps on the motor. If you are not at nameplate amps, change the motor sheave. A little bigger sheave will spin the pump faster, and raise the amps. Faster = more cfm. This is within reason though. Too fast will scatter the pump. They make an adjustable motor sheave, so you can tweak it in. Take amp readings just before the switch shuts it off.
01-05-2012, 12:44 AM | #3 |
You didn't say what you started with, so I can't tell you if this is more cfm. If the question was what's a good compressor to run off of a 3.5 hp motor, then Grainger 2WGX7 would be my answer. It will make 8.5 cfm @135 on a 3.5motor. As mentioned above you will more than likely be changing drive sheaves as well.
01-05-2012, 12:56 AM | #4 |
Well I needed up fixing mine by taking it apart and putting it back togather??? Don't know what the problem was but its fixed now but I am in the market for a two stage 80 gallon!
