04-24-2003, 09:54 AM | #1 |
Tailgate swapping questions
Let me begin by saying that imported repro tailgates suck. Years of loading dirtbikes in and out of it left me with the ugliest most bowed out tailgate anyone has ever seen. I won't scar you guys with a picture.
Well... last night I stuck a different tailgate on the back of my 68'. I picked up an original for $20 at a swapmeet! It's not bowed at all. It has very little rusting at the bottom. It has a few small dings but those should work out. Anyway, here are my questions: 1) My bedsides are leaning inwards at the top so my tailgate rubs the bed as it closes. I know the problem there is my bed. How do I fix this? Should I get a cargo bar to spread the bed out? I want the permanant solution. 2) The new tailgate latch/handle is stiff and hard to pull. How can I make it open easier? How do I grease the latch? Does anyone have an exploded diagram of a tailgate mechanism? It has to operate smoother than this. Thanks in advance! Josh
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
04-24-2003, 10:03 AM | #2 |
I will agree that a certain brand of tailgates do suck. But the tailgates that the vendors on the board(For the ones I know where they get them from) are of great quality. That would be the ones from Fit-Rite(triplus) or Goodmark. I have seen the ones that will bow if it rains real hard on them.LOL I sold a tailgate to a member of this board and three 200 lb men sat on them with no problem and he also carrys loads of steel and wood and the tailgate still looks great. My .02
David
1970 Chevrolet Suburban 1967 Chevrolet C/10 Shortbed Stepside |
04-24-2003, 10:08 AM | #3 |
Resident Curmudgeon
The tailgate latch is easy.
1. Unbolt latch assembly to lower it enough to gain access to the latch actuating rods. 2. Push latch actuating rods out of the holes in the latch mechanism. These are held in by a special fastener. If your mechanism is not rusty the fastener should come out intact and be suitable for use during reassembly. This will free up latch for removal. 3. Unbolt latch catches from tailgate sides. This will allow you to pull catch and rod out. Make note of how the rod is installed for reassembly, or do one side at a time. 4. Clean and lubricate everything and reinstall in reverse order. Can't help with bedsides, sorry
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-24-2003, 10:29 AM | #4 |
Yep, I've heard the Goodmark ones are good.
So, loosen or remove the 3 bolts from the backside of the tailgate. Then I should be able to remove the rods going to each latch? This will be under the handle? Thanks.
04-24-2003, 11:01 AM | #5 |
Resident Curmudgeon
you got it.
04-25-2003, 10:51 AM | #6 |
Well...I took it all apart last night. Greased everything up.
It works great! The springs on the ends are some strong mofo's. They almost feel too strong. Thanks for the help CPNE and kingparts!!!
04-29-2003, 11:06 PM | #7 |
Which tailgates from Goodmark are good? They have the basic no lettering and then the ones that claim to be reproduction parts with lettering the difference is about $100.
I would like a new gate but the last one I ordered after UPS got done with it looked worse than the original tailgate.
67 Fleetside Shortie, small window, slip & slide tranny Upgrades--small block, tilt column, disc 5 lug conversion (front and rear), Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG) |
04-30-2003, 08:09 AM | #8 |
I've heard that the ones with lettering are the good ones. I've never seen one but that's what I've heard.
04-30-2003, 02:12 PM | #9 |
Now the others dig........
Dudes...there is areal straight looking tailgate, like redish-orange color at this salvage yard In San Antonio. the paint is in great shape, no dents trim good too...with the lettering.....sorry I know it's alittle ways away...
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
04-30-2003, 03:04 PM | #10 |
I wonder if that yard ships? If it's straight, I'll buy it! Do you have a phone number for the place?
