01-02-2012, 03:17 PM | #1 |
Reassembling the upper and lower a-arms.
Now i have been into cars my whole life, but never have i done a truck front end. So i'm not sure where to start, these are just set on there, i have all the shims, also i have a 69 manual, and my truck is a 72. I'm guessing they are the same other than the discs?
Here is where i'm at, and what i'm using. Am i to assume just torque the threaded ends to 160 FT LBS. It says to center the bushings in the arms, but i see know way to center it, as i can thread them completely in both sides. Maybe i'm missing something, (wrong manual?) but they are the same as the ones i removed, and those were all loose, so i couldn't get a meausurement. Thank for any help.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
01-02-2012, 06:11 PM | #2 |
Re: Reassembling the upper and lower a-arms.
interested also..will be doing this soon
01-03-2012, 08:38 AM | #3 |
Anyone?
01-03-2012, 06:39 PM | #4 |
I'm just glad to be here!
The cross shaft looks centered in the A-Arm to me in the pictures. I would thread in the bushings all the way and torque as per the spec.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-03-2012, 08:07 PM | #5 |
Old Duffer
No Moa, my manual showed essentially the same figure, but had a different reference point for a dimension. Other than that the directions were the same. Shims between the bar and crossmember for alignment. Might be worth a trip to an alignment shop and pick the mech's brain a little.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
01-04-2012, 02:20 AM | #6 |
This is what mine looked like after I installed new cross shafts. This is the drivers side.
01-04-2012, 04:39 AM | #7 |
Looks like your missing the spacers. I put this back together the way it came apart I think. There should be the washers then the spacers and then shims. As far as the center of the cross shaft I just bottomed both bushing caps out.
01-04-2012, 09:54 AM | #8 |
One thing i did notice, just looking at jbice70gmc's picture, i think my arms are on the wrong side. I need to look at the other truck, i can't believe i'd be stupid enough to do that. Wait, ya i probably am. I never thought to mark them.
I do have all hte spacers and shims i just haven't added them yet. Thanks guys
