Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-02-2012, 03:46 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
4"-5" Grinder Wheel
How long does a metal cutting blade last for a 4"-5" grinder? I'm thinking about cutting lots of 3/8" and 1/4" plate steel. How long would a regular HD or Lowes wheel last doing that?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-02-2012, 09:59 PM   #2
skidpan
Re: 4"-5" Grinder Wheel
I use then cutting .250 wall 2x3 tube, which is 1/4 inch if you didn't know. They last a decent amount of time. You just have to take your time. Grab 10 disks and when you start getting low get some more.
skidpan is offline   Reply With Quote
Old 01-02-2012, 10:51 PM   #3
Notch1988
Notch1988's Avatar
Two factors to consider, brand of zip disc and the user. I find the best are Walter brand and as for the user, let the disc do the work, don`t force it
Notch1988 is offline   Reply With Quote
Old 01-03-2012, 08:34 AM   #4
donut
donut's Avatar
Not as long as you'd like. Don't force it, if you can only use the edge. Life of the wheel drops off fast if you go full depth on the wheel.
I have used wheels to cut up to 3/8", but if your doing lots of cutting I'd look into other means. If I'm only doing a quick cut, I'll use the grinder. More than 1 or 2, I'd drag out the torch, but that's just me.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-05-2012, 09:07 PM   #5
scrapmetalart
Junior Member
I think donut is on the right path. if you have a lot to cut the torch would be the most cost effective. plasma would be better but a lot more loot.
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-08-2012, 11:36 PM   #6
crushermechanic
crushermechanic's Avatar
if you have to use a grinder try to find a wheel that is made for cutting stainless. they will last 2-3 times as long as a wheel for mild steel.
crushermechanic is offline   Reply With Quote
Old 01-09-2012, 10:47 AM   #7
eldogg
eldogg's Avatar
I've had great luck with the Harbor Freight flap wheels & cut off wheels. They are way cheaper too..
eldogg is offline   Reply With Quote
Old 01-26-2012, 02:48 PM   #8
dracko
dracko's Avatar
if you aren't cutting in tight places and cant afford a plasma cutter, a band saw or portable band saw works great.
dracko is offline   Reply With Quote
