Old 01-03-2012, 02:13 PM   #1
72peace
72peace's Avatar
Steering Column or Trans issues?
When the truck is cold, I have issues shifting into park. From what I understand when shifting into park, the column slides towards the driver slightly then moves into place. When it's cold, it doesn't. I think it's a lubrication issue with the column and praying it's not the trans. Is there a way to re-grease the column? Any thoughts anyone?
Thanks,
350/TH350/nontilt
72peace is offline   Reply With Quote
Old 01-03-2012, 04:11 PM   #2
playstock
Re: Steering Column or Trans issues?
I couldn't get out of the park position in my truck. I sprayed wd-40 where the shifter goes into the column. I never had a problem since. From the park position, I pull the shifter towards me then down into the gears if that's what you mean.
playstock is offline   Reply With Quote
Old 01-03-2012, 05:04 PM   #3
72peace
72peace's Avatar
Yes, that's it, it works the same way going into Park. So you sprayed on the right side where the shifter hinges?
Thanks,
Old 01-03-2012, 05:09 PM   #4
Wrenchbender Ret
It is easy & best to drive ut the pin that holds the lever in. Pull the lever out & you can spray around inside. Put the lever back in & tap the pin back. If this doesnt do it spray on the lower part of the columbn where the lever comes out that goes to the trans.
Wrenchbender Ret is offline   Reply With Quote
Old 01-03-2012, 05:24 PM   #5
playstock
I just sprayed in the column where the shifter attaches to it and pivots. I also sprayed all the linkages from the column to the transmission.
Old 01-03-2012, 05:18 PM   #6
72peace
72peace's Avatar
Thanks, I'll try that.
Old 01-03-2012, 05:38 PM   #7
72peace
72peace's Avatar
So basically spray the H*** out of it and everything around it.
Thanks again,
Old 01-03-2012, 06:03 PM   #8
cdowns
cdowns's Avatar
it ia amazin how a 40year old movin part responds to cleanin and lubin
Old 01-03-2012, 07:22 PM   #9
72peace
72peace's Avatar
It's amazing how these 50 year old parts respond to Glucosamine...
Old 01-03-2012, 07:28 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Be sure and place something on the bottom of the column to protect the carpet if you spray or lube it heavy.
On my 69 I actually had to remove the column and I wound up taking chunks of dried up old grease and relubed it. These hot Texas summers can dry even grease.
68gmsee is offline   Reply With Quote
Old 01-04-2012, 03:06 PM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
LMAO!!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-04-2012, 07:40 AM   #12
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Had the same thing on my 66 Impala. Just sprayed all the linkage workings with WD and never looked back. lol Works real smooth since.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-04-2012, 03:34 PM   #13
72peace
72peace's Avatar
It worked great guys, I took the easy route and just sprayed everything without taking it apart. I feel stupid for fighting with this for a year and not doing anything about it.
Thanks again and cheers,
Old 01-04-2012, 04:22 PM   #14
c1069
c1069's Avatar
or try this product work a lot better than WD-40 https://kimballmidwest.com/catalog/C...0.345.231.2123
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 04-07-2012, 06:35 PM   #15
THENEWMEXICAN
THENEWMEXICAN's Avatar
I installed a new printed circuit on my '70 Blazer this afternoon, put everything back together and ****, my whole shift and steering column seem to rotate and shift. I can simply pull the column shifter to the right, my whole steering column will rotate and shift... I have no idea what can possibly be broken or misaligned... any help or ideas. where is the catch to stop the column from rotating?
THENEWMEXICAN is offline   Reply With Quote
Old 04-07-2012, 06:45 PM   #16
john
member #16
john's Avatar
There is a slot on the top of the column tube that lines up with a protrusion on the column bracket. That should keep it from rotating.
john is offline   Reply With Quote
