Old 01-03-2012, 10:16 PM   #1
dukcaln
dukcaln's Avatar
side molding adhesive ?'s
so I finally located and bought some very good almost perfect upper side molding for my 72 LB. What do you all suggest for adhesive for the plastic clips that go on the side of the truck. I was thinking some of the 3m double sided adhesive pads. Any and all suggestions please.
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 01-03-2012, 11:15 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: side molding adhesive ?'s
3M is what you want. Just make sure it's automotive quality.
Zoomin is offline   Reply With Quote
Old 01-03-2012, 11:26 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Yep, that would be with the red peel off backing. That's what I used on my '71.
LockDoc
Leon
Old 01-04-2012, 01:42 AM   #4
dukcaln
dukcaln's Avatar
3m with red back, thanks.... any local auto store I take it
SOLD 1972 chevy c10
Old 01-04-2012, 02:30 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
I get it at walmart as it's cheaper...just make sure to get the auto grade not the craft stuff as it's not as strong (get it from the auto dept where the touch up paint is usually)
Old 01-04-2012, 09:36 AM   #6
LockDoc
LockDoc's Avatar
I got mine at NAPA. I'm 20 miles from the nearest Wally-World...Shop local!..
LockDoc
Leon
Old 01-04-2012, 02:00 PM   #7
dukcaln
dukcaln's Avatar
Local for sure !
SOLD 1972 chevy c10
Old 01-05-2012, 12:54 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
I guess I should note that I literally have two walmarts within 3 miles of my house..the one I go to most is within 1 mile (about 3 minutes away if I catch the lights just right).......and six walmarts within 25 minutes of my house...
Old 01-05-2012, 01:46 PM   #9
dukcaln
dukcaln's Avatar
we have 3 wal marts seperate towns but all 10 min away
SOLD 1972 chevy c10
Old 08-08-2012, 05:54 PM   #10
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
What about these?
http://www.classicparts.com/1969-72-...tinfo/62-892B/
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 08-08-2012, 07:52 PM   #11
big bad orange
big bad orange's Avatar
Unhappy Re: side molding adhesive ?'s
so screw are not how suppose to be used to hold the top trim to the body?
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town"
big bad orange is offline   Reply With Quote
Old 08-08-2012, 08:41 PM   #12
slikside
slikside's Avatar
From what I hear...easier to line up, no drilling necessary (if adding trim),
works good, lasts longtime.
slikside is offline   Reply With Quote
Old 08-09-2012, 12:33 AM   #13
ray_mcavoy
GM used several types of clips to attach the 69-72 upper body side molding.
- Front fender & cab corner moldings use metal clips with studs that are secured with nuts on the back side.
- Door moldings have a screw at the front and a stud-clip w/nut at the rear edge. The remaining clips in the middle are either springy metal type clips that snap into holes or the adhesive backed plastic clips. I believe GM used the snap-in clips for 69-70 and the adhesive ones for 71-72.
- Bedside moldings have a metal snap-in clip at each end for all years. The remaining clips in the middle are either more snap-in clips (69-70) or the adhesive backed clips (71-72).
The adhesive backed clips could be used in more locations than they were from the factory to reduce the number of holes. Especially on the front fenders.
Dang, that's a lot of walmarts! I'm about 45 miles from the nearest walmart
ray_mcavoy is offline   Reply With Quote
