Old 01-04-2012, 01:23 PM   #1
LDO
LDO's Avatar
Rear End Questions
Well, I feel guilty about monopolizing Captainfab's PM inbox so I figured I'd give him a break and ask in the general forum.
I have a 64 12 bolt rearend that I'm planning on installing in my 57 3100. Before I do, I'd like to install fresh wheel axle bearings and seals. The guy at NAPA keeps asking me about H033 & H035 and I don't know exactly what it means. If anyone has the correct bearing and seal PNs that I can use, or cross into a NAPA #, I would be most greatful.
I also found this link here:
http://www.pbase.com/nufsed/drumbrake
that explains all the drum brake components and order of assembly. Is this a good reference for my 64 components or are they different?
Thanks in advance.
LDO is offline   Reply With Quote
Old 01-04-2012, 01:49 PM   #2
1963c-10
1963c-10's Avatar
Re: Rear End Questions
The 12 bolt that you have should have the GM corp 8 7/8" rearend. The HO33/HO35 axle are the old style corp axles. I only have my 63 book in front of me, but will bring my 64 book in tomorrow if no one else pipes in.
1964 Short bed trailer
Old 01-04-2012, 01:54 PM   #3
LDO
LDO's Avatar
thanks, that's starting to make a little sense now. The notes on the NAPA website says... "w/ H033, H035 Axles,2nd Design" sounds like I have the 2nd design?
Old 01-05-2012, 01:09 AM   #4
Captainfab
60-66 Nut
The HO33/35 designation refers to the 1/2 ton differentials used from the second design '55 thru the '62 model year. In '63 the 12 bolt ( 8-7/8" ring gear) was introduced, and in use in the C10's thru the '82 model year.....'79-'80 in the K10's. The bearings and seals will be the same from '63-'82 in a C10. The brakes will be the same from '63 thru about '75-'76, with the self adjusters starting in '66.
Old 01-05-2012, 07:31 AM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
So,just to be clear on this Capt.,this is how I'm reading it
HO33 and HO35= '55 -'62.
'63 -'82= nothing to do with HO33/35.
The '63-'82 are referred to as 8 7/8 corporate.
Bearings and seals the same for pre '69 and post '71 despite the difference in axle length.
Correct?
I,too,have been shopping for rear diff parts and came across the same confusion as LDO,I've foung lots of the HO33/35 stuff, but nothing that really positively identifies(matches) my '65 8 7/8 corp rear.
Great info to know Capt. Thank you.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 01-05-2012, 09:13 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
Hey welcome LDO, glad you could make it to this site, and hope you continue, great site for info on your truck, alias 406Rich.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-06-2012, 01:20 AM   #7
Captainfab
60-66 Nut
That is correct. In my experience, all the parts for the '63-'82 truck 12 bolts are interchangeable. Not just bearings and seals, but gears, carriers, brakes, etc. A couple of things to look out for though, are the 17 spline axles used in '63 and '64, and of course the different length axles starting in late '70.
Correct?
T
Old 01-06-2012, 08:48 AM   #8
LDO
LDO's Avatar
Thanks Rich.
And thanks to everyone else who posts up answers and advice. Like I always say, "there is value in knowledge but passing it on is priceless!"
Semper Fi!
LDO
Old 01-05-2012, 09:55 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Link:
https://picasaweb.google.com/normanm...eat=directlink
Old 01-06-2012, 07:26 PM   #10
aerotruk63
aerotruk63's Avatar
63 had backing plates that were pressed onto the spline of the differential.
Old 01-07-2012, 09:53 PM   #11
LDO
LDO's Avatar
One more question here. My rear has what appears to be a dust/dirt shield between the back of the axle flange and the grease seal. The wheel studs actually go thru it too. When I removed mine, it looked as if there was some sort of gasket between the face of this dust shield and the back of the axle flange????
Old 01-08-2012, 11:29 AM   #12
LDO
LDO's Avatar
Also
How do you know if th axles are good to go?
Old 01-08-2012, 01:00 PM   #13
LDO
LDO's Avatar
Here is what they look like. Nothing leaked or had excessive play before the teardown...
Old 01-08-2012, 09:43 PM   #14
Rich 5150 69
You`re good to go..just re-install seals, and maybe bearings.....
Old 01-08-2012, 10:11 PM   #15
Rich 5150 69
I used a slide hammer with an old set of hub puller jaws inverted to grab the inside of the bearing, and yes there is a lip to allow the bearing to go in only so far.
Old 01-08-2012, 10:13 PM   #16
LDO
LDO's Avatar
Should I be able to feel it with my finger inside there and tell where the lip is and the bearing is?
I don't want the puller jaws to latch on to the wrong lip (if that's even possible)....
Old 01-08-2012, 10:48 PM   #17
63sbssbbw
UCA63
63sbssbbw's Avatar
Not possible LDO the lip should only be high enough to stop the outer part of the bearing,also your pulling away from it.
T
member#7816
'61 GMC in progress
Old 01-08-2012, 10:52 PM   #18
LDO
LDO's Avatar
Thanks.
I will re-attack tomorrow with a slide hammer that carries a little more ass.
Old 01-09-2012, 01:42 AM   #19
Captainfab
60-66 Nut
I can see some wear on the axle. Can you feel a difference in the diameter LDO?
Old 01-09-2012, 09:33 AM   #20
LDO
LDO's Avatar
Capt. - I will check it today after work and I clean it up a little. I hope I don't need new axles, that would suck!
But if I do, should I go ahead and upgrade to 30 spline (w/new spiders)??
any recommendations on brand/companies, etc...
Old 01-09-2012, 07:40 PM   #21
LDO
LDO's Avatar
Tonight I came home with a proper bearing removal tool rented/borrowed from Autozone and it worked perfectly. Got the bearing out and the shim/washer behind it. Thanks to all who gave me the gouge on the removal.
I am pretty sure the axles are salvageable. I'll hit them with some scotchbrite and see what happens.
Old 01-10-2012, 08:54 AM   #22
63sbssbbw
UCA63
63sbssbbw's Avatar
Capt,Assuming that this is a wear spot...Any fixing it?,or is the axle toast?
What about spray welding(cold) and remachining,,A viable option or?
T
member#7816
'61 GMC in progress
Old 01-11-2012, 12:57 AM   #23
Captainfab
60-66 Nut
You can get those 'axle saver' bearings that move the bearing outboard the width of the bearing. I don't think welding and machining the axles would be very cost effective. That would probably cost more than new replacement axles.
T
Old 01-14-2012, 10:07 AM   #24
orgalmeister
Just guessing here but if someone had been in there before is it possible these are not the original axles? and they were shimmed out to make up the difference?
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
Old 01-14-2012, 12:45 PM   #25
bama63
bama63's Avatar
the only thing the shims could possibly do is move the bearing outward on the axle surface as the c-clips and cross pin set the axle end play. as for oil flow the axle pulls the lube as it turns (like a barber pole) so they should lube fine but...the oil could get trapped between the seal and bearing and not return properly so as captainfab stated i would definitely drill the 1/4 inch hole in the bottom of the shim if i installed them.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
