01-08-2012, 01:32 PM | #1 |
sensor
there is a sensor of some kind located behind the throttle body on my 6.0 thats broke off, what is it?...searched but came up with f.a.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-08-2012, 01:45 PM | #2 |
meowMEOWmeowMEOW
Re: sensor
EGR, don't bother plugging it in, you'll remove it in your tune anyway. You can pull it out and replace it with a plug, or anything that won't leave a vacuum leak.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
01-08-2012, 01:56 PM | #3 |
Re: sensor
thanks.
01-08-2012, 02:37 PM | #4 |
Has more rust than truck...
Re: sensor
Actually its the EVAP solenoid, but still the same answer. Plug it and have your tuner turn off all the EVAP codes.
01-08-2012, 10:16 PM | #5 |
meowMEOWmeowMEOW
Re: sensor
^you are correct. I just pulled it out and threw it in the garbage either way
01-08-2012, 10:19 PM | #6 |
Re: sensor
thanks...mines broke off so thats where it's goin.
03-01-2012, 01:26 AM | #8 |
Re: sensor
I left the evap in place and put a rubber nipple/cap over the tubing. It's all hidden under the cover anyways.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
03-01-2012, 10:01 AM | #9 |
Re: sensor
X2, or if you're an oger like me and break the thing off a 1/4 NPT plug will screw in.
