C35 Crew Dually
moving hanger and shackles
Will moving the hanger and shackle up one hole on the frame work on my one ton? I know it works on 1/2 tons thanks
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
C35 Crew Dually
Re: moving hanger and shackles
lol anyone?
Yes you will gain about 3 inches.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
C35 Crew Dually
thanks because with the springs i have in my truck it sits 3inch higher than it should after i put drop hanger and shackles.
C35 Crew Dually
do you move both up? because i just looked at my pics and my shakle holder has only 4 rivits....
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 01-12-2012 at 09:40 PM. |
yes you have to grind the heads of the rivits off and punch them through the frame then replace with Grade 8 bolts.
C35 Crew Dually
no i know that as i did that with my hanger but if i move the shackle hanger up only 2 holes with be lined up with the frame will only 2 be enough? lol noticed i missed some info in my last post fixed it now.
Happy to be here
![]() Join Date: Mar 2000
No, two is not enough. You will need to drill two new holes.
C35 Crew Dually
thanks but i just was looking under the truck and i have to do a stock spring pack swap as my 2inch shackles already almost hit the bed floor
Ya in the rear you have to do shackles or move them , one or the other not both
C35 Crew Dually
the prob is the ark are my springs because it use to be a tow truck and had 26 leafs aside :S
Had the same springs in mine when I did my BUDGET drop. Ended up taking out 16 leafs, i would have to go look in the snow bank. Replaced the centering pin, used STOCK shackles and moved BOTH hangers up the frame. Not as low as I want it but it works for now.
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!" Last edited by Racker; 01-13-2012 at 01:59 PM. |
#13 | |
C35 Crew Dually
Holly Cow, I'm guessing mine where a little softer than yours. Have you moved the hangers up yet?
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!" |
