Lowering a gmc with leafs?
Looking to lower my 66 gmc short bed step side. Can't find much info because most of you lucky guys don't have leaf springs.
Looking to do 4/5 or 4/6 2" spindles and 2" springs for the front? Axle flip for rear? Any how-to's? I read on a different site about a guy that did an axle flip and had to shorten his driveshaft 2"?? Any advice is appreciated.. Thanks guys -Paul Posted via Mobile Device
1966 GMC stepdside shortbed- needs some love |
![]() Join Date: Sep 2009
Re: Lowering a gmc with leafs?
i took all but the 3 long leafs off and put on lowering shackles. lowered the truck about 3-4 inches. it's hard to find flip kits for these trucks they have
2 1/4 inch wide leafs most others have 2 1/2 leafs. |
#3 | |
Resistance is Futile
My '64 shorty has leafs and is flipped. I think a couple leafs were removed also. (Done by PO). I put in a new rear; you just need axle mounts for a 3'' tube and weld them on. Available everywhere and cheap.
Cant help you with the driveshaft issue; I re-did my whole driveline and moved my engine forward so I have no point of reference to start with. I had to get my driveshaft re-done. You may have to play with the shocks for correct travel??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
67-72 parts collector,…
![]() Join Date: Nov 2002
DJM makes a flip kit for these trucks.
(DJM-FK1012-5) Look at Summit Racing. They have them in stock. http://www.djmsuspension.com/applica...63C10Parts.htm http://www.summitracing.com/parts/DJM-FK1012-5/
#6 | |
Keepin it old school
Did anyone ever confirm the kit working on 60s trucks? Thinking about buying one if so, current setup isn't working out too well.
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
So 70-72 is the same as a 66?
I would say so.
The other option is a drop leaf spring like these from ECE. http://www.earlyclassic.com/Tech.asp...=Spring%20Time I think the flip kit would be easier.
Performance online also has drop leaf springs:
http://www.performanceonline.com/196...AF-SPRING-SET/ They list them as 66-72 or 73-87.
Damn I didn't realize how expensive drop spindles are I'm trying to get those done on a budget. I might end up going with 3" drop springs up front, shackles and remove a couple leafs for the back. For now at least, I hate cutting corners but I have ALOT to do to get this thing road worthy by spring lol. Thanks for the links, I saved them.
Drop spindles are $228 at Performance Online every day.
Didn't check out the link yet, but then wouldn't I have to convert to disc brakes? Everything adds up
#15 |
i went with ECE shackles
#16 | |
But I would spend my money on disc brakes,... way before I lowered anything.
#17 |
I used 2" drop a-frames in the front and took 2 short springs out of the leafs and re-arched them rides great
#18 |
Mine has PDB
#19 |
What's PDB?
It will eventually get disc brakes, just not yet Posted via Mobile Device
#20 |
Power disc brakes, I put mine on after I lowered it I just had to change Lower ball joints, I don't know, if the rest of the form belive in lowerd a-arms and I have never used droped spindles, but mine looks good and handles great
#21 |
i have a set if 3in. dropped front springs if interested
#22 |
Pm me with price, shipped to 02375
![]() Posted via Mobile Device
#23 |
C/10 junkie
I lowered my 72 with the 4" drop monoleafs from GMC Pauls and the 2" rear drop shackles from CPP. The rear still wasn't low enough so I installed a cnotch and raised the front hangers up 2". All of this can be seen on my homepage gallery of the 1972. The front drop for referance was ECE 2 1/2" drop spindles and 2" CPP drop springs.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#24 |
I have a GMC C1000 SWB. I lowered it first by removing every other leaf spring ( I believe I removed 5 leaf's). It was not low enough, so I put a drop shackle on the rear. It got it very close to where I wanted it, but not enough. So finally, I removed the shortest, stubby, leaf. Now, its just right. I remember I had to have 4 new U-bolts bent because there were no threads left to thread. I got the shackles on ebay from CPP - 63-72 Chevy Truck Rear 1"- 2" Drop Leaf Spring Shackles.
Good Luck.
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
#25 |
I went with the CPP dropped spindle disc conversion, I also went to a 5" on 5" bolt pattern and re-drilled my axles to the same pattern so I could run modern looking 5 lug wheels. Out back I flipped my set up by cutting off the perches and re-welded them to the same rear end. I set the pinion angle and welded it up. I had already had the stock springs re-arched so when I was done the rear end was just to low so I drilled out the rivets and remounted the front spring hangers 2 Inches lower on the frame, this raised the truck one inch.
this is with the dropped spindles and re-arched springs pre flip this is the front perch after I boxed in the top and re-welded it to the frame. notch in place ready to weld after, And I love the new stance. out in the world |
