More 1963 and 1965 parts
Here are some more items from my 65 parts truck. The previous owner had some 63 parts mixed in as well.
PRICES REDUCED!!! Please look at my other post. After some additional research I was too high on some of my pricing, so I reduced the price to get them moving. http://67-72chevytrucks.com/vboard/s...d.php?t=501213 1965 Inner Door Panels - Good condition. Obviously scratched. Not bent or curved. Very few minor dents. - $35 Pair obo. DROPPED TO $25 1965 Custom Cab Sail Panels. Passenger side has minor dents, probably can be pushed out. Curved sections in good condition. - $35 Pair obo. SOLD! No-Name Mirrors. I don't know what they came off of. Mounting brackets and screws included. $5 pair. Motor Mounts - Good condition with light surface rust. I don't know if they are from a 6 cyl or V-8 - $40 pair obo. DROPPED TO $25
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-26-2012 at 02:00 PM. Reason: PRICE DROP |
Re: More 1963 and 1965 parts
Tail light housings and bezels. Housings are in decent condition. Both bezels are dented. - $10 for everything.
Inner door handles and window cranks. Driver condition. Light to moderate pitting. - $15 for all 4 obo. SOLD! Upper Radiator Support Bracket. Not cracked or damaged. - $10. DROPPED TO $5 1965 Headlight buckets and aluminum trim rings. - Buckets are in excellent condition. Trim rings are in very good condition. One is slightly bent, but should straighten out when installed. Mounting tabs are still intact. - $20 DROPPED TO $15 1965 Cowl Extension Panels Good condition, no dents or bondo. Slight surface rust on inside. - $30 for both. DROPPED TO $25 1965 C10 Emblems - Very good driver condition. - Mounting studs in good condition and nuts included. - $15 for both. SOLD!
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-26-2012 at 01:55 PM. |
1963 Grille Support. No dents, bends or bondo. All body lines are perfectly straight. OEM condition. Light surface rust on backside. Someone looked at it and said it was the best original condition one he has seen in 15 years. - $175 obo. DROPPED TO $150
1965 Glove Box Door - Mounting bracket attached. Unfortunately I don't have a key for lock. Not Dented, light surface rust on backside. - $15. DROPPED TO $10 Sold! Hood Latches - Good condition, light surface rust. $10 each. 1965 Fresh air vents. Drivers side in good condition. Passenger side has welded repair handle. Hardware included. - $15 both. Sold!
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-27-2012 at 11:07 AM. |
Window frames. They came off of the 1965 parts truck, but not sure if they are original. Someone said they may be GMC safety glass frames. Window supports are in new condition. No rust at all and no bends. Window frame portion has very light surface rust on some spots. Glass was shot out before I bought the truck so there is no glass. - $50 each. SOLD!
Air Cleaner Box. Not dented or damaged. Its been repainted at one time. Some rust. - $15 SOLD! Driver Side Inner Fender Panel. No dents. Surface rust, but no rust thru. $35 SOLD! Passenger Side Inner Fender Panel. No dents. Surface rust, typical small rust thru under battery. - $15
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-26-2012 at 10:02 PM. |
1965 Doors. Solid condition except where some jacka$$ cut speaker holes in the doors. Both are in good driver condition. Driver door has dent from front fender, but in good condition otherwise. Passenger door is not quite a good. There is some bondo in the center of the outer door panel. Both are solid otherwise. Drivers door - $35 obo. SOLD! Passenger door - $25 obo. SOLD!
Cowl Panel - Excellent condition. No rust or dents and all the grill spaces are straight. - $25 DROPPED TO $20 Wiper transmission arms - Good condition. No damage or rust and doesn't squeak. - $20 DROPPED TO $15
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-26-2012 at 01:57 PM. |
1965 Long Bed - Good driver condition. Not perfect but nice. Drivers side is excellent, passenger side has one spot of bondo. Side panel end returns are excellent. I don't see any rust thru anywhere. The bed had a 10 gage steel floor that was very poorly welded in, so I removed that 2 weeks ago. The bed panels are not damaged from the welding. It was welded in 3 spots. There will be some light grinding on a couple spots to remove the welding marks and 3 small pieces. Side panels and cross braces are the best part. The front panel has a slight curve at the bottom probably from something heavy sliding forward and hitting it. I have a lot of pictures available, please send me your e-mail address and I'll send them.
Price includes all cross braces, left and right side bed panels, front panel, side braces, wheel wells and tailgate. I'll also help you take it off and load it up. ![]() 1963 Chromed glove box door and ash tray. Pitted, but has great patina. Shined up really nice. Door - $20 DROPPED TO $15 Ash tray - $10.DROPPED TO $5
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-28-2012 at 06:01 PM. |
#7 | |
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#8 | |
Thank you, Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD. |
Can you get me a total price on shipping to 30157?
![]() Join Date: Feb 2010
Im lookin for rear bumper brackets(4pcs)?
I wish I had them also. The previous owner had some ultra heavy duty bumper put on the back. There's a tag on it for 10,000lb max capacity. The brackets are missing, but he welded on some 1/4" plate steel to use as a bracket. The front bumper brackets are there, but they have a curve in them so he must have bumped into something hard.
just had another thought. I may be open to trading as well. I need both bumpers and brackets, radiator, stainless strips for the bed, exhaust, grill, 2001+ Silverado seat, radio, power steering, disc brakes. Let me know what you have.
Kevin C
I am interested in the mirrors, doors and probably a few more parts, will have to check on Monday. I will PM with a full list.
I will take the fresh air vents. Shipped to 43343. PM me your info, paypal
#15 | ||
2001shadowace - PM Sent - Thank you!
#16 |
paypal sent, I have pm'ed you thanks!
#17 |
I am interested in the emblems,.If you still have them?
Why can't I find it until the last place looked? 65 Longbed 283 three on the tree. 66 Longbed 292 three on the tree.Pennys A/C Trucks made in USA Buy a much as you can, Made in the USA |
#18 |
2001shadowace & DanSan C 10, payments received and shipping arranged. They will go out tomorrow.
Thank you, Kevin C
#19 |
I'm interested in the bed. I sent you an IM about it. My email which I forgot to include is jjz44z@hotmail.com Thanks Jeff
#20 | |
Thank you, Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD. Last edited by kevinc; 01-22-2012 at 10:30 AM. |
#21 |
Thank you Kevin I will look forward to there arrival. Dan
#22 |
what about the custom trim will they sell for 30 if so ill take them off your hands
#23 | |
Thank you, Kevin C
#24 |
Selling one pair of front bumper brackets. Arrow straight with surface rust. $30 or best offer.
#25 |
TTT w/ Reduced Prices...
