Old 01-12-2012, 01:57 PM   #1
blackmopar
Dropping the Front on the 64
ok - so there are a million threads that touch on this - I didnt know which to try and resurrect - plus my searches never find the actual topic im looking for anyway.
So this is my daily beater - Ive posted in its current form on some other threads - she hasnt seen much makeover lately - just been my reliable driver - and i lover her for it
SO - currently I only have CPP drop springs and shocks - 3 front and 4 rear.
I love where the rear is (although i need to get some airlift load bladders to haul much more than leaves and balsa wood) but the front is our focus here. There really was NO stance change up front with the drop springs from stock. Some reading leads me to believe its sort fo a hit or miss with how low these trucks go with static drops - sometimes I see guys where all they did was cut a coil from stock springs and they are sitting way lower than me.
Leads me to the actual topic:
Ive got the speedway (CPP) 2.5" drop spindles and disc kit that Im getting ready to install.
I want her to have a raked stance - similar to this dudes SWB - you think Im gonna get there with this drop kit only or am I gonna need to modify springs some more too??
blackmopar is offline   Reply With Quote
Old 01-12-2012, 02:17 PM   #2
NCD1966
NCD1966's Avatar
Re: Dropping the Front on the 64
well as i was reading i was thinking of you need to put some drop spindles on it. Since you are, try that and see how it comes out.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 01-12-2012, 02:42 PM   #3
blackmopar
here is the rake im hoping to get - reasonable to think I should get there with 2.5" drops with the 3" CPP springs?
Old 01-12-2012, 02:54 PM   #4
blackmopar
here are a couple more that I would be ec'static' (pun intended) with!
Old 01-12-2012, 03:35 PM   #5
SIR
SIR
SIR's Avatar
This drop was done with 2 1/2 drop spindles & 1" drop springs when it settled down to aprox 3"...the rear is a 4" drop springs..we also went with a anti sway bar in front, cornering is great!!....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 01-12-2012, 02:52 PM   #6
blackmopar
caffeine has started to subside - my real intent/point of this thread is hopefully someone with this kit/springs can tell me where Im gonna be sitting or what else I need to get to sit like this - as menitoend this is my DD and all my wrneching is done 70 miles from home at a buddies shop - when i did the spring drop about 2 years ago I was dissapointed with the outcome but had to get her back together so I dont have alotta trial and error time
Old 01-12-2012, 03:50 PM   #7
blackmopar
very nice SIR - looks like this is what I should expect then huh since sounds like you used exact same parts as I have - Wonder if I cut a half/full coil off my springs would get me a c-hair further ......... id like a bit more rake if I can
great looking longbed!
Old 01-12-2012, 04:45 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
With the coils and springs you will be at 5.5''. IMO it should be in the neighborhood of the gray truck with the tire just at the fender lip give or take a bit. I base this on my 64 SB with the same set-up although different manufacturers. Do you have a smallblock in that?? Dont know the weight of a 6-banger which would make a difference.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-12-2012, 05:51 PM   #9
forestb
forestb's Avatar
Here is mine with a 4.5 inch drop with 2 different tire sizes. I would say that a 5.5 inch drop would put the front cross member closer to the ground than I would like. My lower A arms scrape on stuff as it is. Also if you want that much of a rake I would be worried about sliding off the front seats.
forestb is offline   Reply With Quote
Old 01-12-2012, 06:08 PM   #10
Slow Build
Slow Build's Avatar
Your picture at the top of the thread doesn't look lowered at all in the front. Are your springs seated right? Seems pretty high for have 3" drop springs in front. I wouldn't cut any more off of a the spring if in fact they are 3" drop spring. Back looks good though.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-12-2012, 10:20 PM   #11
S-31
What size tires are you running on this one in both pics?
S-31 is offline   Reply With Quote
Old 01-12-2012, 06:36 PM   #12
blackmopar
well - I ordered FCS6102-3 1963-72 Coil Springs front 3" drop, pair but they were black - the photo they now have are yellow!? I believe they are seated properly
this was a couple years ago at this point - wonder if they WERENT 3" drop springs - is there a way I can tell?
I do have a SBC 350
Old 01-12-2012, 06:57 PM   #13
protrash64
protrash64's Avatar
I dont remember seeing any stamps or printing on my CPP coils; I think they may have to be gauged to tell.
If you decide to cut them, only cut a 1/2 coil at a time. I cut 1'' lowering springs one coil and turned them into 3'' drop really fast! You can check out my '66 thread and see. I wanted the truck about 1/2 to 1'' higher. Also the disc's will kick your front track out about 3/4'' each side, so tire diameter and rim width become a consideration.
Really opens the can of worms.
Old 01-12-2012, 07:21 PM   #14
blackmopar
any idea what they should mic to?
Old 01-12-2012, 07:07 PM   #15
blackmopar
thanks for that info ProTrash. I will check your thread out - I know I need to get new front rims obviously since Ill have 5x5 up front - so I will need to compensate with 1" additional backsapcing to get the same 'track width' as I have now?
Old 01-12-2012, 07:16 PM   #16
XtechX
XtechX's Avatar
Do you have the stock front springs still? If so maybe you can compare them to the springs you bought. It does look about stock height in the front.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 01-12-2012, 07:22 PM   #17
blackmopar
negative ghost rider - and I 'thought' I remember that they were a little taller but I could totally be wrong at this point
Old 01-12-2012, 08:09 PM   #18
gimmy 64
i have 3 in. dropped springs for sale if you are interested.
gimmy 64 is offline   Reply With Quote
Old 01-12-2012, 08:25 PM   #19
blackmopar
Gimmy - its funny you bring that up as I just got off the phone with CPP and checking my order history I purchased the 2: drop spring for the front apparently - although I still am suspect that might have actually gott stock or 1" drop - anyway that dont matter now -
How much you want for them my slightly northern brother?
Old 01-12-2012, 08:51 PM   #20
protrash64
protrash64's Avatar
Yes if thats an issue to you, but mostly, if you get too low and widen the front your tires will contact the fender lip. My 6-lug ralleys with 235/70/15's rub just a little on some turns and if I turn and hit a bump or incline. I believe the tire is about 28'' in diameter. Like I said, thats the can of worms!!
None whatsoever.
Old 01-12-2012, 10:17 PM   #21
Narxoleptic Customs
if u have ab 3" of tire sidewall just deflate the tire to see if ull like the way it looks. Its how i decided i needed to b 3" lower in the rear bc i liked the look one morning when i came out and my tire was flat.... If u have 2" springs now I wd not cut any off til u see how low the spindles drop u. And if u do cut, only cut 1/4 coil at a time so u can make adjustments for ride height side to side.
Narxoleptic Customs is offline   Reply With Quote
Old 01-13-2012, 12:37 AM   #22
blackmopar
not a bad idea Narx, thanks
Old 01-13-2012, 10:21 AM   #23
gcwhite
Here is mine with 2.5 spindles and 3 inch springs in the front. 5 inch springs in the rear and I have 235/75-15 tires.
1998 K3500 Crew Cab-daily driver
1987 1ton Blazer
1982 2WD Blazer
1970 C3500 dump truck
There is NO replacement for displacement!!!!
gcwhite is offline   Reply With Quote
Old 01-13-2012, 12:19 PM   #24
blackmopar
GC - attaboy! that looks pretty spot on to stance Im trying to get here - Did you stay with 6 lug or swap to 5? Did you need to mess with backspace for the new rims?
Old 01-13-2012, 04:12 PM   #25
blackmopar
GCWhite and ProTrash......you both have the 2.5" drop spindles and 3" drop springs - for a total of 5.5" drop - do either of you have a ground clearance issue with your front crossmember?
someone raised that concern here (and Ive seen elsewhere) and I have a chance to grab 3" springs from Gimmy here but wanna make sure 5.5" total isnt too low for a static drop
thanks all!
