Old 01-13-2012, 11:21 PM   #1
Holt
Drop spindle question
i have a 67 c10 but have 5 bolt axles, my front axle has disk brakes, i changed calipers and 1972 calipers matched up with what i was taking off so should i be safe in using 1972 for drop spindles?
Holt is offline   Reply With Quote
Old 01-14-2012, 01:31 AM   #2
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: Drop spindle question
You can use spindles for 71-72 or 73-87....the later model ones use a different tie rod end. IIRC the calipers are the same for both versions...so that probably isn't a good indicator of what you have now. I'd order the 71-72's and if they don't work return 'em and get the 73-87 style.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 01-14-2012, 10:54 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
71-72 and 73-87 spindles are different.
The calipers will work on either IF the rotors are 1-1/4" wide.
There is also 1" wide light duty rotor for the 81-87 trucks.
These take a different spindle, rotor, caliper, and bearings.
Your upper balljoint and outer tie rods will determine which spindles you have.
Do you have any pics of you suspension?
Spindle area and a-arm pics?
Keith
Convert to disc brakes.
Old 01-14-2012, 03:51 PM   #4
Holt
how do i post pics? cant find thread on it.
Old 01-14-2012, 05:27 PM   #5
lolife99
lolife99's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=209103
Keith
Old 01-14-2012, 09:38 PM   #6
Holt
This is what i have can anyone tell if it is 71-72
Old 01-14-2012, 10:28 PM   #7
Holt
ttt
Old 01-15-2012, 12:20 AM   #8
lolife99
lolife99's Avatar
Do you have steel "screw-in bushings on the a-arms or rubber bushings.
Thos are definitely standard spindles.
Keith
Old 01-15-2012, 02:03 PM   #9
Holt
what drop spindles are recommended? is one brand better than another?
