Old 01-13-2012, 11:42 PM   #1
Mandrew
I want to lower my truck.
i want to lower my 1977 C10 but kinda on a budget (my budget being almost no money) is there anyway to do this without spending hundreds of dollars? and without sacrificing frame strength... please help and thank you.
Mandrew is offline   Reply With Quote
Old 01-13-2012, 11:45 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: I want to lower my truck.
moving hangers = $0 + time
cutting coil = $0 + time
drop shackles = $ little + time
There are lots of ways to lower our trucks without spending much money. The ways that require no money usually take more time and labor but will accomplish the same things as expensive kits.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-13-2012, 11:50 PM   #3
Mandrew
Thanks for the info man my buddy was telling me to take the leaf spring axel plate(?) cut it off and weld it back on the bottom so the leafs sit under the axel, does that affect driving feel? like "dogtracking"
Old 01-13-2012, 11:56 PM   #4
THE "10" SILVERADO
That would be a "flip kit". It changes the position of the leafs above the axle. Just search in the box at the top of here for flip kits and tons of hits will come up. It's a pretty common way to lower our trucks but I'm not sure how much the kits cost.
Michael
Old 01-14-2012, 12:00 AM   #5
Mandrew
since i am new to this lowering stuff will it affect tire wear? or is that if i drop the front to much to put it in the negative camber? and i will search flip kits to get more usefull tips.
Old 01-14-2012, 01:28 AM   #6
stepside-mitch
stepside-mitch's Avatar
you will need an alignment
stepside-mitch is offline   Reply With Quote
Old 01-14-2012, 10:06 AM   #7
J Knight
J Knight's Avatar
If you want a $0 drop I would recommend 2/4, cut one round of of the coil springs for 2in in the front and move your shackles and hangers up 4 inchs.
If you drop more than that without buying at least spindles, flip brackets, and shock extenders or drop shocks you are going to have issues to deal with like not having enough bolt to add shims for proper alighment, excessive front tire wear, rear shocks bottoming out. Also flipping your spring perch to the bottom without drilling an alignment hole towards the front to effectively keep your rear end from being located to far forward will possibly result in jamming your drive shaft into your tranny and improper pinion angle.
Some kits imo come with more stuff than you realy need and are pricey, but realistically you can get a 3-5 drop in the front for the cost of a drop spindle ($225-$250) and a 5-6 drop in the rear for the cost of a cheap flip bracket and shock extenders ($95-$125).
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-15-2012, 03:42 PM   #8
Mandrew
So whats the purpose of buying a "flip kit" if everything in the kit is what you take off and (depends on which one you purchase) have to weld, besides the fact of getting lowering springs, and new bump stops as far as i can see in the flip kit pictures.
Old 01-15-2012, 07:41 PM   #9
J Knight
J Knight's Avatar
When you install a flip kit you dont remove anything but the factory bumpstop and the mount for it. The flip bracket does more than just abapt the rear end to the top of the spings, it also maintains proper pinion angle, its alignment hole is offset to keep the axle centered in the wheel opening which also keep the drive shaft from binding (jamming into the trans). Shock extenders keep your shocks from bottoming out and keeps them at the right angle.
You can fab your own brackets or flip your spring perch and fab a shock extender if you dont buy drop shocks. Just keep in mind that these are issues you need to address in your fabrication. Below is a pic of flip bracket dementions if you want to fab one up instead of moving your spring perch and a pic of the shock extenders for reference.
John
Old 01-15-2012, 07:49 PM   #10
mud.man.rj
mud.man.rj's Avatar
You can always pull the second leaf from the top on the rear, no cost at least 2-3" drop, cut one loop front coils, 2" free drop.
mud.man.rj is offline   Reply With Quote
Old 01-15-2012, 10:11 PM   #11
bark
hey, is that your pdf with the flip bracket specs? I sent you a pm, I need to build some of those
bark is offline   Reply With Quote
Old 01-15-2012, 10:14 PM   #12
J Knight
J Knight's Avatar
I got it off of another site, it was posted that way. I tried to enlarge it and turn it with no luck. Maybe someone can photoshop a close up of it.
John
Old 01-18-2012, 10:04 AM   #13
Desert1957
Desert1957's Avatar
Here you go
Desert
Desert1957 is offline   Reply With Quote
Old 01-16-2012, 12:35 AM   #14
gGMC DOG
Thats just a screenshot of a PDF file its not actualy a PDF file, heres a link to an actual PDF file.
http://67-72chevytrucks.com/vboard/s...&postcount=368
gGMC DOG is offline   Reply With Quote
Old 01-15-2012, 09:57 PM   #15
oldschool18
oldschool18's Avatar
Using a flip kit is quick and pretty easy, cutting the front coils if you never took coil springs out before is not very quick not the best ride you could want and you can get yourself hurt if you dont know what your doing. flip kit it the rear would be cheap but I would get a set of spindles ( ithink Chassistech.com sells for about 250 ) or a set of lowering springs for the front. when I lowered my first C-10 I got lowering leafs and spindles they set me back about 400.00. if you dont got it save up to get it cause there is nothing worse that than fearing pot holes and man covers when your driving down the road.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-16-2012, 01:13 AM   #16
gGMC DOG
for those of you that don't have a pdf reader, you can right click and save the image, save it to your desktop, open it up with microsoft paint, a standard program for windows. use your magnifying tool to enlarge to get your measurements. no photoshop necessary.
Old 01-16-2012, 02:15 AM   #17
Mandrew
thanks again for al lthe useful tips from all you guys, so, im pretty sureim gonna do the kit and all the necessary brackets, due to my truck being a not a high dollar show truck but something older gentlemen and GM fans a like can appreciate, in the end no one really wants to see a nice restored truck with the moeny put into it like that why skimp on the lowering?
Old 01-16-2012, 02:25 AM   #18
gGMC DOG
never skimp on the lowering. get the best parts you can get. i simply posted what i posted to clear up some things. be sure to take plenty of pics and post them
Old 01-16-2012, 11:44 PM   #19
Mandrew
I soon hope to make a build thread soon, just need to get money, i've changed my mind on budget wise so no skimping, no cutting corners, nothing. oh and does anyone know where i can find a decent billet grill other than LMC Summit Ebay or Vatozone?
Old 01-18-2012, 10:27 AM   #20
jitteryguy
GoatLube Experss
jitteryguy's Avatar
save the bittet grill money for somethen to make the truck look good, like drop spindle's.
also the $30.00 shackle kit that AutoZone sell's will fit your truck and lower it 2"
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-19-2012, 05:20 PM   #21
gGMC DOG
i just bought a set last month and they were $40. just make sure to carry your old ones in to match them up cause my nephew picked them up, and they were the wrong ones, so we had to return those and get the correct ones. seems all their packaging is the same.
Old 01-17-2012, 10:45 PM   #22
Mandrew
Hey J knight, did your kit come with springs? and how much was that kit in the picture?
Old 01-18-2012, 10:34 AM   #23
J Knight
J Knight's Avatar
The pic in post #9 is everything I installed. I got it all from Stylintrucks, $340. McGaughys 2.5 spindles $245 DJM flip bracket with shock extenders $94.99
John
Old 01-18-2012, 07:23 AM   #24
J Knight
J Knight's Avatar
No, I cut one round off of the factiry springs.
John
Old 01-21-2012, 10:58 PM   #25
ghettoluxury
ghettoluxury's Avatar
On the flip bracket does the hole go to the front of the truck or the rear?
Thanks.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
