01-15-2012, 03:03 PM | #1 |
oil pan
Does anyone know if you can remove the oil pan on a small block with it still in the truck?
Trying not to pull the motor just to put a new oil pan on. I have a 70 c10 2wd. Posted via Mobile Device |
01-15-2012, 09:00 PM | #2 |
Re: oil pan
You may need to lift the engine/tranny up with a cherry picker in order for the pan to slide out.
project: "my happy mess" |
01-15-2012, 09:52 PM | #3 |
Re: oil pan
Disconnect the motor mounts, jack the engine up so you can get a piece of 2x4 in the space between the engine and frame mount.
If you jack against the oil pan, use a piece of wood to spread the load so you don't bend the pan. http://67-72chevytrucks.com/vboard/s...&postcount=195
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
01-16-2012, 07:12 AM | #4 |
Re: oil pan
Thanks for the answers, at least I can have a ideal of what to expect when I start to change the oil pan and gasket. Thanks
01-16-2012, 11:04 AM | #5 |
Re: oil pan
When you jack up the motor watch for any other things that can get stretched like the rad hoses or power steering hoses or rad shroud. I unbolted my rad when I did mine and let it slide up and loosened my PS pump so the hoses could move further.
01-16-2012, 11:18 AM | #6 |
Re: oil pan
Like geezer#99 says, too.
01-16-2012, 11:40 AM | #7 |
Active Member
Re: oil pan
Also check the distributor especially if it's an HEI and very close to the firewall. I had to remove mine. If you have a shroud make sure the fan will clear it. Don't forget the fuel pump hose and the exhaust pipe.
Basically just use caution and make sure everything clears. |
Tags |
motor, oil, remove |
