Old 01-15-2012, 08:58 PM   #1
MYNAMEISMUD
MYNAMEISMUD's Avatar
Bedliner on door panels...
Mine looked like garbage, so I sprayed them with bedliner. The truck is about the get rebuilt , but 'til then this looks pretty good for $9. Pretty easy, figured I'd share.........
THE DEVIL MADE ME DO IT!
MYNAMEISMUD is offline   Reply With Quote
Old 01-15-2012, 09:08 PM   #2
J Knight
J Knight's Avatar
Re: Bedliner on door panels...
It looks like it came out like black dye. Did it leave or add any texture?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-15-2012, 09:14 PM   #3
MYNAMEISMUD
It does add a slight texture. Kind of like a grip-taped skateboard, with paint on it. Really, perfect for the door panels.
Old 01-15-2012, 09:30 PM   #4
str8axle55
Looks good, I like it.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 01-15-2012, 09:56 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
That turned out purdy good !
What kind of prep did you do before spray'n ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-15-2012, 11:11 PM   #6
MYNAMEISMUD
I wiped it with Acetone, then hit it with Scotchbrite....then Acetone again. The first cleaning with Acetone is so you don't grind the crud in with the Scothbrite.
Old 01-15-2012, 11:19 PM   #7
Texasupton1
Now why couldnt you do the same thing with a dash pad? Trim up the cracks, fill them in with some sort of plastic body filler or such, then spray with bed liner. Couldnt you then use a something like Plastikote with color to go over the bed liner?
Texasupton1 is offline   Reply With Quote
Old 01-15-2012, 10:10 PM   #8
Pop's C-10
Pop's C-10's Avatar
nice work
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-15-2012, 11:07 PM   #9
JRANGER
JRANGER's Avatar
Damn now to decide between this or Krylon....Nice though, I like it it a lot
JRANGER is offline   Reply With Quote
Old 01-15-2012, 11:31 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
boy those look real good .....wonder if it would crack at -40 C
plastic coat i've used would still scratch
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-15-2012, 11:35 PM   #11
MYNAMEISMUD
@Motornut....I'm not sure about the temperature tolerances. I make it a habit to never go anywhere that the temp gets below freezing.....ever, no matter what
Old 01-16-2012, 08:01 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
I wish, lol there are colder places then here , it's -26 this morning,-33 windchill
that may blow some peoples minds,and rads lol
John
Old 01-16-2012, 02:00 AM   #13
oldschool18
oldschool18's Avatar
I used to you that stone chip gaurd stuff you would spray on the bottom half of you ext and down on the rockers panels when I built tweeters into the plastic pillars by the winshields. it gave a nice texture. I did the bedliner stuff on door panels before and in the heat it was very easy to scratch that stuff off
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-16-2012, 03:43 AM   #14
TheApocalyptican
TheApocalyptican's Avatar
Looks good.
Just as an fyi for anyone else who wants to do this....the rustoleum is better for less texture. In my experience(which is many cans)the duplicolor spray bedliner is much more textured than the rustoleum.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 01-16-2012, 03:51 AM   #15
iceship
I was going to line-x my doorpanels but the grit is just so big... Thats never coming off...
iceship is offline   Reply With Quote
Old 01-16-2012, 10:45 AM   #16
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I have several Kawasaki Terex's , some of em were spay'd with Line-X.
grant'd I've had these here for right a year, the Line-X is peel'n off in sheet's. when it come's off it look's like they prep'd em good , it's just once a spot does break loose and the air can get to it spread's quickly.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-12-2012, 10:13 PM   #17
iceship
Motornut... is it soft rubbery or hard.... so do you still like it so far..
Old 02-14-2012, 10:25 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
Wasn't me ,it was mynameismud
John
Old 02-15-2012, 01:51 AM   #19
ivorton74
ivorton74's Avatar
that looks like something i wanna try.my door panels look all faded and ugly
ivorton74 is offline   Reply With Quote
Old 02-15-2012, 11:24 AM   #20
Weasel Diesel
I love spray on bedliner stuff. You can hide all sorts of flaws with that stuff. I figure if it can hide nasty flaws on the truck that good, It ought to be safe enough and worth the try to spray the wife with...
Weasel Diesel is offline   Reply With Quote
Old 08-03-2012, 01:33 AM   #21
iceship
What brand did you use..
