Old 01-17-2012, 03:32 PM   #1
airbrusher
lowering
i have a 72 short wide i have installed cpp 4 inch drop coils along with there 2.5 inch aluminum blocks and i still set to high in the back what is a fairly economical way to drop the back more? i guess i thought 6.5 inches would drop it more thanks
airbrusher is offline   Reply With Quote
Old 01-17-2012, 03:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering
Drop blocks would be the best,... unless you want to swap out the springs.
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Keith
Convert to disc brakes.
Old 01-17-2012, 04:12 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: lowering
6.5 is a lot of drop without a c notch.You also have to understand that 6.5 of drop,probably isn't.That figure is from what it should have set new to 6.5 below that.The truck had probably settled over the years.That may have made your 6.5 as little as 4 in of drop.I personnally wouldn't go more than what you have with a static drop,but that's just me.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-17-2012, 06:46 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Re: lowering
They make a 2.5" block? I've never heard of that and only see 2" on their website. Not saying you're wrong or anything, but just trying to clarify.
I've seen people run a 5/7 drop around here, but a lot depends on your tire height. Got any pics of what it looks like now?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-17-2012, 09:22 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Re: lowering
Early Classic Enterprises carries 6" drop rear coils...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-18-2012, 12:54 AM   #6
airbrusher
Re: lowering
my bad the blocks are indeed 2.5 inches billet aluminum but they are not cpp at this moment i cant even recall whose they are i cant get pics to load at the moment or i would post some thanks all..
