Old 01-18-2012, 08:10 AM   #1
Generallee
6 cyl to V8
Is it reasonably easy to change my straight 6 for a small block 350? I have a 350 gearbox, will that work OK and is bolt pattern the same. Its a 1980 C30 2WD pickup.
Any advice helpful.
Generallee is offline   Reply With Quote
Old 01-18-2012, 10:29 AM   #2
J Knight
J Knight's Avatar
Re: 6 cyl to V8
The only thing I remember having to do was to move the motor mounts to the other set of holes in the brackets.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-18-2012, 06:43 PM   #3
FritzA
Re: 6 cyl to V8
Should be straightforward. Most everything should hook/bolt right up.
You didn't mention what year the truck is and what 6 engine it is. If it is the 250 you may not even need to move the motor mounts.
FritzA is offline   Reply With Quote
Old 01-18-2012, 08:56 PM   #4
77chevyinline6
77chevyinline6's Avatar
Re: 6 cyl to V8
im thinking of putting a 307 in to replace my worn out 250 six. its 3 on the tree everything should bolt up fine?
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 01-20-2012, 04:37 AM   #5
Generallee
Re: 6 cyl to V8
Its a 1980 C30, with a 250ci. 3 on the tree auto.
Drives lovely apart from the motor being a little worn.
Am now on the look out for a 350 I think.
Thanks for the advice.
Old 01-20-2012, 04:44 AM   #6
mike73
mike73's Avatar
Re: 6 cyl to V8
3 on the tree auto?
mike73 is offline   Reply With Quote
