01-22-2012, 02:21 PM | #1 |
front suspension changes 67-72 to 74-87
Can anyone tell me if the 74-87 C10 has an improved front suspension & brakes over the 67-72?
What are the physical differences? What are the handling differences? Thanks for your help. |
01-22-2012, 03:15 PM | #2 | |
Re: front suspension changes 67-72 to 74-87
Rubber bushings in a shell vs rubber lined steel sleeve offered more isolation for a smoother ride & less vibration being transmitted to passangers. Bump stops are slightly different because of the slightly different spindles for drum vs disc applications. Handling? While the post-72 bushings offer a smoother ride quality, they also will flex more meaning slop/give vs precise alignment when pushed in corners.
01-23-2012, 11:34 AM | #3 |
Thanks for the info.
Does anyone know if it is possible to swap 73+ control arms, spindles, & disk brakes on a pre 72 C10? Thanks |
01-23-2012, 01:52 PM | #4 |
Yep. All will swap....
01-24-2012, 11:23 AM | #5 |
Are the front tracks different or the same? Can someone tell me what the front track is for each range of years? Thanks |
01-24-2012, 11:54 AM | #6 |
I have sold 50 73up disc brake setups for the 67-72 trucks. The best and easiest IMO is to unbolt the engine crossmember (with all of the suspension/brakes) off the 73 frame and bolt it onto your 67-72 frame. You will have to drill a couple of holes to get all 7 on each side fastened. If you don't care about the upgraded bushings, use a 71-72 disc setup on your 67-70.
01-24-2012, 12:32 PM | #7 |
Happy to be here
Here's some great info for you- "Drum to Disc" conversions 60-70
01-24-2012, 12:35 PM | #8 |
Will the front track remain the same when the cross member is replaced?
Thanks |
01-24-2012, 04:26 PM | #9 |
6x-70 drum front ends to 71-87 disc get wider. 71-72 disc to 73-87 disc front ends there's no change. The disc spindles & hardware causes an increase vs the drum set-up.
01-24-2012, 12:50 PM | #10 |
Happy to be here
yes
01-24-2012, 12:53 PM | #11 |
