Old 01-25-2012, 02:10 AM   #1
Mike Quillici
No headlights. . .
I drove to work today, and my headlights worked. I then drove to a meeting, and my headlights worked. Then I left my meeting, and no headlights. My tail lights work, side marker lights work, high beams work, dash lights work, dome light works, but no headlights.
So, I drove home with my high beams on. Alas. My question, though, is this likely a switch issue? What's the best way to track down this electrical gremlin?
1972 Chevy C-10 ~ 188,000 miles give or take
Mike Quillici is offline   Reply With Quote
Old 01-25-2012, 02:29 AM   #2
Kurt L
Kurt L's Avatar
Re: No headlights. . .
check your dimer switch,i bought a truck one time and didn't have head lights turned out it was the dimmer switch. it was all corroded[sp] and i put a new one in and had lights it's worth a try.
Kurt L is offline   Reply With Quote
Old 01-25-2012, 02:36 AM   #3
Mike Quillici
The dimmer switch seems to work fine in all regards, except for the headlight function. No flickering or odd operation. But a switch sounds like a cheap fix.
Old 01-25-2012, 04:21 AM   #4
19Hoosierdaddies68
My headlights don't work sometimes as well, seems to be the high beam switch on the floor. right now I just keep clicking it until the headlights come back. Maybe check to see if a wire came loose or fell off.
19Hoosierdaddies68 is offline   Reply With Quote
Old 01-25-2012, 04:53 AM   #5
MikeyMan
I would replace the dimmer floor switch and check the plug & wiring that goes to it.
If all you other lights work properly, I would suspect the dimmer connection.
MikeyMan is offline   Reply With Quote
Old 01-25-2012, 07:35 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Try wiggling the plugs on the back of the headlights. (with switch on in low beam) Alot of times there's a bad connection there.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-25-2012, 08:28 AM   #7
oklalawnboy
oklalawnboy's Avatar
My vote goes to the dimmer switch.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 01-25-2012, 09:11 AM   #8
mrein3
mrein3's Avatar
If wiggling the plug down by the dimmer switch gets you your headlights back, you have a cheap, easy fix in your future.
Go to NAPA and buy three pieces of part number 725147. You can go to NAPA online and see what they look like.
Go home, unplug the dimmer switch, mark/write down/remember where each wire goes then remove each wire from the connector. There is a little tab on the wire terminal that needs to be depressed with a little flat blade screwdriver to get the wire and terminal out.
Cut off the old, green, furry terminal. Clamp on your new terminal. Insert the wire where it came from. In reality you only need to remember what the "in" wire is to that switch. The high and low can be swapped as the switch doesn't care it just alternates between the two circuits.
I would take this time to clean the male connectors on the switch as long as you got your hands dirty. Brush them clean then apply a little electrical grease so the connection will last another 40 years.
Screw dimmer switch back down and plug in your re-habbed connector.
Done in about 30 minutes and for less than a crappy cup of coffee.
You'll be so happy and in for so little money at this point that I suggest you search this forum for "relay headlight upgrade" and put another $15 or so bucks into your lighting system. (You'll need 6 more 725147 and two relays and some 10 or 12 gauge wire). When done you'll wonder how you drove for 40 years at night without the relays.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-25-2012, 09:51 AM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
Normally its the dimmer switch or the headlight switch going bad. It could also be your connection at your wiring harness block on the cab. Have you had it a part lately?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-25-2012, 11:31 AM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Great advice above. Since the high beams works, your dashboard switch is OK, and grounds are also OK. Everything points to either the dimmer switch or a poor connection at the dimmer switch.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-25-2012, 10:40 PM   #11
rkn463
rkn463's Avatar
Unless both bulbs burned out the low beam filament at the same time I don't see how it could be anything but the dimmer switch. You should be able to verify with a short length of wire: disconnect the plug, turn on the lights, find the "hot" with a volt meter or test light, then jump it to each of the other two wires one at a time. One should be low beams, the other high.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-26-2012, 01:27 AM   #12
Mike Quillici
$20 in replacement parts, and it turns out it was a loose wire. . .
Oh well. I now have a new headlight switch and a new dimmer switch. Thanks for all the help.
Old 01-27-2012, 12:29 AM   #13
rkn463
rkn463's Avatar
Just for future generations, where was the loose wire?
Old 01-27-2012, 01:35 AM   #14
Mike Quillici
It was a loose wire on the plug to the floor dimmer switch...
Old 03-18-2014, 02:42 AM   #15
1969GMCTruck2500
Smile Re: No headlights. . .
Great information on this forum!
The topics on headlight problems helped me figure out the connections were bad at the dimmer switch. I was beginning to suspect the headlights themselves and I looked at the ground wires also. I jumped the three wires together at the dimmer switch and all four headlights lit up!
The PO torn up the dimmer switch connector looking in the wrong place for a short in the wiring(I found a short in the alternator soon after I bought the truck). I ordered a dimmer switch and a dimmer switch connector at Rock Auto.
1969GMCTruck2500 is offline   Reply With Quote
Old 08-21-2016, 04:26 AM   #16
Magnafyed
Mistakenly crossed positive and negative posts.
Headlights stopped working.
This forum is most helpful. I had looked to many places.
I am glad I waited to take action..
My issue was also the connection at the dimmer .
Crossing the wires must give just enough energy to create a loss of connection.
Very fortunate that was all it did.
I had already replaced the dimmer.
I just cleaned the gak from around the contacts, installed and removed the plug a few times and carefully applied some dielectric grease to the spades and connector.
Instant headlights !
In the process found a ground for a backup light I had installed that had fallen off.
That works again as well !
Great forum ! The shared info is very much appreciated .
Magnafyed is offline   Reply With Quote
Old 08-21-2016, 08:24 AM   #17
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
I bet it's a loose wire.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 08-21-2016, 09:39 AM   #18
custom10nut
custom10nut's Avatar
Clean all your contact, and dab a little dielectric grease on them. Over time humidity causes corrosion build up and a break in contact. Another thing I do is to get some electrical contact cleaner, and spray into the female portion, to clean the hard to get to contact points. One last thing is to check all your grounds. These to are prone to the corrosion phantom
custom10nut is offline   Reply With Quote
