Old 01-25-2012, 01:54 PM   #1
idaho66stepside
idaho66stepside's Avatar
Fuel Cell ?
. When putting in a fuel cell in the frame which way should the sump and fuel lines point, to the front or the rear?
idaho66stepside is offline   Reply With Quote
Old 01-25-2012, 02:04 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Fuel Cell ?
Is this going to be for a drag racing application?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-25-2012, 05:28 PM   #3
idaho66stepside
Re: Fuel Cell ?
Nope just for the street.
Old 01-26-2012, 11:29 AM   #4
vin63
vin63's Avatar
Re: Fuel Cell ?
If this is a street vehicle only, be sure to mount the cell so that the sump is at the lowest point. You can mount it in either direction for fuel line routing convenience, but if you mount the cell so that the sump is to the rear, take into consideration the rake of the chassis.
Old 01-29-2012, 06:14 PM   #5
bubba327
HOW long until spring??
bubba327's Avatar
Re: Fuel Cell ?
I have the pick up tube shaded closer to the passenger side.
I thought that if I would pull over to the side of the road on the shoulder, I did not want to run out of gas if it was already low...
For race application, they say to put it at the rear so when you launch, the fuel is forced to the rear .
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 01-29-2012, 07:53 PM   #6
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Fuel Cell ?
also dont forget that the fuel line will be on the left side of the frame in 99% of all builds.
GMR-PERFORMANCE is offline   Reply With Quote
