01-26-2012, 01:45 AM | #1 |
Question On Frames 1968 GMC
What's The Difference In A 1/2 Frame To A 1 Ton Frame..
I Found. A 1968 GMC 4 Wheeler K10... I Have All 1 Ton Leafs And Axles That I Want To Use on My Tow Rig.. But Clean 68 3/4 Tons are Hard To Find... Going To Tow a 5th Wheel Trailer... Posted via Mobile Device
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
01-26-2012, 08:20 AM | #2 |
Re: Question On Frames 1968 GMC
One tone frames are made with taller rails. This has nothing to do with the springs,though. I guess you want to know if C/30s have the same eye to eye length as the K/10 and if the spring pad spread is the same. I can't answer that with any certainty,but will say you can move the rear spring hanger if they are different (I think they're the same...52") and you can move the spring pads/weld new ones if the spread is different. I know k-model frames taper in more than c-models,so springs sit closer together. Is you C/30 axle from a single wheel? I believe they will need to be moved.
01-26-2012, 10:04 AM | #3 | |
The Hunts On Again... need a 68 K30 Posted via Mobile Device
01-27-2012, 08:43 AM | #4 |
You know there's no such thing as 67-72 K/30,right? I think you can do what you are wanting off a 1/2 or 3/4 ton frame. The 1t frames are taller under the cab at the widest part of the frames. I'm not sure the height is any different back under the bed. I think maybe the C/30 and K-model frames have the same spread,too...maybe.
