235 dual carb questions
I have a strong 235 in my '62 - I'm thinking about getting a dual carb setup.
I am running Fenton headers, so I don't have any heat riser, are there any dual setups that address this? Also, if I do go to the dual setup, what changes do I need to make to the two 1-barrel carbs? Any experience with these? Thanks for your help! |
Re: 235 dual carb questions
I did this on my '52 and I got a plate with fittings for coolant to run through the heat riser. It takes a little bit longer than the exhaust to heat up but works fine after warming up. I know that Tom Langdon sells the coolant plate and also has 2 holley 2 bbl from a ford fiesta or focus that are supposed to be the best setup to make power. Id definitely check langdons stovebolts out.
Yeah...Tom Langdon is the man with L6 mods
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
