01-27-2012, 12:54 AM | #1 |
WTBUY 4 barrel carb
I have a 1964 327 -300 horse 4 brl intake that I would like to put a Rochester 4jet or a Carter that fits on it ..so anyone who is familiar with this application and has one that will fit, in working condition FS please LMK
thanks
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-27-2012, 01:11 AM | #2 |
Just a Member
Re: WTBUY 4 barrel carb
I have like 15 4-jets sitting in my garage... I will check the dimensions and square bore and get back with you.. They all vary in condition... let you know
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
01-27-2012, 01:21 AM | #3 |
thanks much appreciated
Jess
01-27-2012, 01:26 AM | #4 |
Just a Member
What is that setting is that micrometer on??? Also what is the dimension of bolt hole center to bolt hole.. I am sure they will work just making it easier on the both of us...
01-27-2012, 10:45 AM | #5 |
Heavy
its set to inches so much for modern tech here is what i have with a good old fashion ruler center to center front to back 5 5/8 side to side 4 1/4 that rear bore is about 1 3/4 with a ruler if you need pics i got them thanks for your help Jess
01-27-2012, 10:53 AM | #6 |
425hp409
The correct carburetor is a Carter AFB. You must also use a stainless steel plate under the carburetor and above the gasket for the exhaust gasses to get to the carburetor to warm it up, but not cause damage to the base of the carburetor. You can also use one of the Edelbrock Performer Carburetors, but I am not real fond of them. What is your application for the intake? I might be able to help you.
Charles
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
01-28-2012, 08:53 AM | #7 |
Hi Zic I will check the carb I have it's fairly new and ran the motor it came in on. I will be up the shop today and post back later.
Posted via Mobile Device |
01-28-2012, 06:00 PM | #8 |
Ok the one I have is off a big block and is most likely not going to work.
01-28-2012, 07:40 PM | #9 |
Steve
no that one wont work thanks for trying jess
01-28-2012, 08:21 PM | #10 |
You bet Jess
01-28-2012, 08:40 PM | #11 |
Just a Member
Hey Jess, I have tracked down 7 so far... Two Holley's and 5 Q-jets. The 5 jets I have found look the same size diameter as the primary and secondaries on Steve's he pictured. I have plenty more just got to track the box down... PLEASE DON'T LAUGH!!! hah my garage is similar in scope to an indoor junkyard at the moment!!!
01-28-2012, 09:28 PM | #12 | |
Duane
i m in the same spot running out a room know i got it just don't no where i left it.......thanks ill wait to see what you come up with.... no hurry on my end ....thanks for looking Jess Quote:
