Eyegore Anyone ever remove trans &... 01-27-2012, 10:41 AM
Dunenutt Re: Anyone ever remove trans... 01-27-2012, 10:51 AM
hairlesshobo Re: Anyone ever remove trans... 01-27-2012, 10:58 AM
Keith Seymore Re: Anyone ever remove trans... 01-27-2012, 11:09 AM
Dunenutt Re: Anyone ever remove trans... 01-27-2012, 11:19 AM
JMS-1 Re: Anyone ever remove trans... 01-27-2012, 01:09 PM
67swb72klb Re: Anyone ever remove trans... 01-27-2012, 01:39 PM
hatzie Re: Anyone ever remove trans... 01-27-2012, 02:16 PM
Eyegore Re: Anyone ever remove trans... 01-27-2012, 02:59 PM
russgt Re: Anyone ever remove trans... 01-28-2012, 05:08 PM
01-27-2012, 10:41 AM | #1 |
What Hump?
Anyone ever remove trans & transfer case by themselves?
I have to pull a turbo 350 & transfer case. I've done it before but not by myself. Can it be done? I'll be using a floor jack trying to balance the trans and transfer case, the truck will be sitting on the ground, no jack stands, seems to be enough room. But in reality can I do this myself? Have any of you done it alone under the same condtions. By the way the last time I pulled a transmission & tc was some 20 years ago.
And I know the transfer case weighs some 250lbs or seems that heavy. Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
01-27-2012, 10:51 AM | #2 |
Newbee
Re: Anyone ever remove trans & transfer case by themselves?
I do it all the time, but in two pieces. Do yourself a favor, and get a trans jack.
http://www.harborfreight.com/450-lb-...ack-39178.html Cheap insurance, one slip may be your last. |
01-27-2012, 10:58 AM | #3 |
I agree, if you can afford it, a trans jack will be an excellent investment for yourself. If you absolutely don't have the money for a trans jack, something I have done in the past is to use two floor jacks and a small piece of plywood.
Another tip, whenever pulling a tranny with a floor jack, make sure you have a 2x4 or something similar handy. You need to place something between the jack and the pan of the transmission or you're liable to crush the pan on the transmission. -Steve
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears |
01-27-2012, 11:09 AM | #4 |
I always use my floor jack and just balance the whole affair on the jack pad. You can also use ratcheting "tie down straps" and make a sling from frame rail to frame rail crosscar, both as a safety feature and/or as and aid in getting it up off the floor and onto the jack initially.
I'm sorry guys, but I CANNOT reccomend the harbor freight trans jack. I have one of those and the scissor portion doesn't want to stay vertical - it will lean off to one side or the other and dump everything onto the floor. I've had a couple close calls and won't use it again. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-27-2012, 11:19 AM | #5 | |
Newbee
Never had an issue with my jack( used 10 times or so). Maybe they cheaped out in the last 10 years. Mine is still tight, and I use an impact to raise and lower it |
01-27-2012, 01:09 PM | #6 |
This might sound crazy but I have seen my dad use a cherry picker with a chain through the trans tunnel when he didn’t have a floor jack. It actually looked fairly easy.
1980 converted C30 454, 4 on the floor... |
01-27-2012, 01:39 PM | #7 |
^ that does work out real good !
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
01-27-2012, 02:16 PM | #8 |
Moderator
I welded a chunk of steel pipe that fit the floor jack saddle hole to the center of a 12"x12"x1/4" plate. I drilled 1/4" holes in the corners for tie straps. I used a second jack to stabilize the transfer case. I installed a 700R4 & NP208 in my 76 by myself with that setup.
01-27-2012, 02:59 PM | #9 |
What Hump?
JMS-1, HATZIE and all the rest those are some great ideas.
Thank you. Tom
01-28-2012, 05:08 PM | #10 |
+3 on removing the trans tunnel and using a cherry picker
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
