04-28-2003, 12:15 PM | #1 |
Ride is BOUNCY after the drop!
What would make the truck so damn bouncy?! I used Spindles/Flip kit, and I can't believe how bouncy it is! It's not like BAM BAM BAM! hard hits, but I mean, it just like a bumpy ride. Is this just how lowered trucks ride? (I guess I've been so used to riding in my vette, I'm used to hitting bumps and going SLAM SLAM SLAM RATTLE RATTLE! I used the DT shocks, that everyone said to get.
04-28-2003, 12:17 PM | #2 |
Hotwheels?
Well... they are 20+ year old springs and bushings. When you get your new front springs it should stiffen it up a bit.
Mine rides a lot less bumpy with my DT's. But it is still a truck. |
04-28-2003, 12:26 PM | #3 | |
04-28-2003, 12:43 PM | #4 |
Under construction!
My truck was the same way, TIMSPEED. Rode rough on back roads but awesome on the highway!
2001 Silverado bagged on 22's. *Sold* |
04-28-2003, 12:44 PM | #5 |
It's not that it rides ROUGH, just like you can feel that their are imperfections in the road...doesn't HURT to hit bumps, you just know that they're there.
04-28-2003, 12:48 PM | #6 |
Insert Witty Text Here
I don't know how long you have had the 17s, but with 17 inch wheels, you don't have as much of a rubber cushion as you did before. The same goes for the urethane bushings. They don't "give" as much as the old rubber ones did. Perhaps these two things can explain some of the harsh ride.
Slonaker |
04-28-2003, 12:56 PM | #7 |
Under construction!
Tim, how does the front-end feel going through corners and down the road?
04-28-2003, 01:03 PM | #8 |
i think you are just expecting to much. its a 30 year old truck man. just drive it and enjoy it
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-28-2003, 01:04 PM | #9 |
I don't think the flip kit will make a difference in ride quality (as long as shock extenders were used). On the other hand, urethane bushings are harder by design so perhaps that's what your noticing.
As for switching from 15's to 17's, as long as the sidewall height is adequate there isn't that much of a noticalbe diff untill you get on a pothole infested road. I switched my 215/75 & 275/60 15's out for my 255/45/18 & 295/40/20's & it rode the same until the previously mentioned potholes.
04-28-2003, 01:17 PM | #10 |
It's not a HARSH ride, it's just bouncy. But when it bounces, it doesn't KEEP bouncing, it's just like "bump" and it's done. As for tire size switching...I went from a 32x11½-15 to a 255/55 17.
04-28-2003, 01:26 PM | #11 |
Dumb question, but did you cut off your rear bump stops? That will make it harsh.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
04-28-2003, 01:32 PM | #12 |
Well, that's just what I call a sport tuned suspension. I'm surprised your vette doesn't ride like that. It's a quick rebound right?
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
04-28-2003, 01:50 PM | #13 | |
04-28-2003, 02:00 PM | #14 |
www.73-87chevytrucks.com
I would think what you are descibing is what I call stiff. As in you hit a bump and it hit is "BUMPing jar" and you are done. Over crappy roads, it can be annoying. Bouncy is what I describe as the springs oscillating to much from bad shocks.
Is the bumpstop gone, did you notch the frame?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-28-2003, 04:33 PM | #15 | |
04-28-2003, 10:34 PM | #16 |
I didnt put on shock extenders because I didnt know about it until I was freaking done. I dont wanna take it all apart again so I'm just gunna let it go. Next week im gunna put in a C section and 2in drop shackles.
84 Chevy Stepside, 350, TH350, 268h Comp cam, Hooker headers, MSD Pro Billet, Edelbrock Performer manifold and 1604 carb, 40 Series Flowmasters dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi |
04-29-2003, 09:05 PM | #17 |
Treat yourself to some new Bilstine shocks, you will think you just bought a new truck it will ride so much better. My 78 did when I lowered it with spindles and hangers and the stock front springs and it has 17" wheels also
