Old 01-28-2012, 08:55 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
3:42's?
I have 3:08's now... but for the time being, since all my funds are going towards the body work on my Mustang, I thought popping in a set of 3:42's in my truck. Plus, I want to get rid of the welded carrier and go with a locker [which I have since it got welded, but it's whatever.]
Think it's worth it? it's a 6.2/700R/NP208. Eventually I'm converting to a standard with an NP205... I'd prefer an MV4500, but if I found one cheap enough I'd go with a 6-speed.
Even when I do the swap, would it be worth leaving the 3:42's in with the standard?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 01-28-2012, 09:56 PM   #2
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Re: 3:42's?
With a 6.2 it may be very different... my blazer has 33, 350, 700R4, and 3.42s. Going down the highway it downshifts to often on a grade. I'm updating mine to 3.73s.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 01-28-2012, 10:38 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
Re: 3:42's?
Really depends on tire size. With 28" tires what you have now is probably fine. 31"-33" would probably work better with 3.42's, but still OK with 3.08's if you aren't in a hurry.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-31-2012, 09:16 PM   #4
Rogue_Alphonse
Re: 3:42's?
I don't plan on ever going with tires bigger than 31", it'll never get a lift more than 2", and it definitely will be getting a standard trans in the future.
As for being in a hurry? Um.... heh... Every time I see the highway I see my speedo needle hit the trip odometer reset
Also I'm not TOO worried about mileage, but now I get 30-32 on the highway... if it drops below 27 I might reconsider...
Old 02-01-2012, 12:44 AM   #5
85sierraclassic
85sierraclassic's Avatar
Re: 3:42's?
my truck was origanaly a 6.2l 700r4 208 with 3.42s but i didnt own it then, but with 33's and the 4spd sm465 it at like 2300 at 60 ish pry more like 65 buy ya know lol.
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 02-01-2012, 02:07 PM   #6
6 2 Carl
6 2 Carl's Avatar
Re: 3:42's?
3.42 gears is a good combination with the 6.2 700r4 and 31" tires. If staying with the auto, and putting on a 2" body lift, I'd go with the 3.73's. But since you are also wanting to swap in a nv4500 I'd stick with the 3.42's. The overdrive ratio is slightly less with the nv4500, 0.73 vs the 0.70 with the 700r4
1987 R10 Chev Suburban 6.2L Diesel
1984 Frame 1990 Body V20 Chev Suburban 6.2L Diesel Banks Turbo
6 2 Carl is offline   Reply With Quote
Old 02-01-2012, 10:23 PM   #7
Rogue_Alphonse
Re: 3:42's?
Exactly the kind of advice I was looking for! So basically you're saying go to the junkyard and pull 'em for probably $15 per carrier assembly including pinion.
