Old 01-30-2012, 03:01 AM   #1
tekno62
Fuel filter location
I was wondering where to put an aftermarket fuel filter - 72 chevy truck
tekno62 is offline   Reply With Quote
Old 01-30-2012, 07:24 AM   #2
MagmaJct
MagmaJct's Avatar
Re: Fuel filter location
My truck has an Edelbrock, but is otherwise stock. The previous owner (my late uncle) didn't install a filter. It eventually flooded the engine because grit jammed the needle valve open.
I installed a filter in the fuel line above the right cylinder head. In hindsight it wasn't a good choice. The lines where they are clamped to the filter are leaking a tad. This is the pressure line, so any leak will show, and it's not in a good place being above the exhaust and all.
If it wasn't all hard lined, I'd consider installing the filter on the suction side of the pump. There would be concern of cavitation or vapor lock. But I'm thinking if a large enough filter is used with high surface area in the filter medium, there should be no problem.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 01-30-2012, 07:38 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I have an inline filter just before the pump on most of my cars/trucks. I use a Fram see thru (plastic) and just put in the rubber hose between the pump and the line that sticks through the frame.
It's easy to get to, out of harms way there and away from the hot engine. Best of all, I don't have to cut any stock metal lines.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-30-2012, 09:38 AM   #4
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Mine has an inline between the pump & carb, I think it's quite a common place to have one mounted.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 01-30-2012, 10:42 AM   #5
cdowns
cdowns's Avatar
fuel filter between pump and carb has been proven to b the best way// having fuel filter b4 the pump makes pump work harder and is less reliable
Old 01-30-2012, 11:29 AM   #6
tekno62
thanks for the fast replys - I was hoping you all could post pictures of your installs for me.
Old 01-30-2012, 12:09 PM   #7
hayhauler71
hayhauler71's Avatar
one under the tank where the rubber hose goes to the steel line on frame and one near the carb
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-30-2012, 12:44 PM   #8
treveiger
treveiger's Avatar
I have one under the carb. Works for me.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-30-2012, 04:56 PM   #9
Wrenchbender Ret
I always put one between the tank & pump unless I have a new tank. Grit can get in the fuel pump check valves & cause failure. Its good to have one in the carb inlet or in the line between the pump & carb like Hayhauler says.
Wrenchbender Ret is offline   Reply With Quote
Old 01-30-2012, 05:16 PM   #10
tekno62
yea I know the check valve on the fuel pump is bad.
