GVW Tags
Just wondering if anybody knows if the gvw tags on the kickpanel are available.I once read about somebody that made replacement tags with your info but i cant find it now. Mine has been scuffed up and painted over and looks pretty ugly. thanks Mark
Re: GVW Tags
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Re: GVW Tags
Anyone have pics of the GVW plate in place on a 66?
Re: GVW Tags
Here's one for a '65. I think '66 is the same.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 01-23-2013 at 03:33 PM. Reason: Fix dead pic link |
Re: GVW Tags
It does not mention the 250 engine.
![]() Join Date: Oct 2009
Re: GVW Tags
here a couple of 66 only items I have. made silkscreen gvw plates from this artwork and also the glovebox option sheet which is photoshop layered artwork to change option lists.
Re: GVW Tags
Re: GVW Tags
cool...thanks!
Re: GVW Tags
I know an old thread but do you still have any of the 66 gvw plates for sale? And if not, would you mind passing along the info for the person that did it so i could get one done (if i need to get more than one done, then i could and offer the rest)
For the super purist, has anyone seen a template for the options sheet that is usually under the seat above the springs? Would LOVE to put one there when i get the seat re-upholstered. |
Re: GVW Tags
hey cortcomp,
i think i still have a few... will check when i get home and pm as soon as i know. thanks, clem |
Re: GVW Tags
Clem, thanks!
Kieth, i see brothers still does have the 65 tags, but yes that's why he had to remake the '66 one, the different motor options. |
Re: GVW Tags
And are those special rivets? Look like standard hollow pop rivets.
#13 | |
Re: GVW Tags
They are extra length Rivnuts. The inside is threaded and have to have a special tool to pull the threaded inner stem toward the flange. ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: GVW Tags
I am also looking for two correct 66 plates. Anyone have a source and some one to stamp them? Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
#15 |
Re: GVW Tags
Wow, all great info! Digging through RPO codes now, not a lot of luck. Want to re-create the glove box sticker in my 66 but having trouble figuring out what code and descriptions to put....had it been a 67 there's tons of info out there! Like on air conditioning, i see it's option A60 but on the sticker it would be C60AG - 4 season air cond? How do you know if you don't have a list or original to compare to?
Details details! |
#16 |
Re: GVW Tags
1966 was the first year GM used this option label. Try board member "Chipflyer" as he can set you up with an authentic looking option tag for just about any GM option.
#17 |
Re: GVW Tags
I will look him up. I don't mind making the label from the template above, just have no idea what the codes are or how to find them!
#18 |
Re: GVW Tags
cortcomp... i've got 2 left on the 66 gvw tags. you're welcome to one of them. they are not cut out or drilled and i haven't stamped them either. i had them screen printed on aluminum from the artwork that i did. i don't think they are perfect but good enough for me. if more folks want them i can get them reprinted...
also i have a photoshop layout on the 66 glovebox lid option sheet but like you i am not sure of all the codes either. it is a layered file that can be altered for any option differences. it is also not perfect as i retouched from a scan of a original in very good shape. since i do this kind of work professionally, i will say that both are pretty darn good. pm me, if i can help |
