Old 01-30-2012, 10:27 PM   #1
six8burban
Oil cooler suggestions?
Mistakenly I Just purchased a trans cooler from jegs instead of a oil cooler. Called to reorder oil cooler and jegs sales guy said I could use the trans cooler as a oil cooler? any suggestions on a oil cooler guys?
six8burban is offline   Reply With Quote
Old 01-30-2012, 10:34 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Oil cooler suggestions?
I don't think you'll get the volume through a trans cooler that you would with an oil cooler.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-30-2012, 10:49 PM   #3
Ranger6202
I know you can get the stock adapter and tubing from GM parts. If you have a stock GM radiator, i believe the cooling lines just hook into the radiator. I have the adapter and tubing if you need pics.
Ranger6202 is offline   Reply With Quote
Old 01-30-2012, 11:00 PM   #4
six8burban
Sure I'm aways open to pics (sewwhut@aol.com). From my understanding the trans cooler gets connected to the rad and oil cooler goes to a separate cooler?
Like one of these:
http://www.jegs.com/p/Earls/Earls-Te...75460/10002/-1
Old 01-30-2012, 11:41 PM   #5
Ranger6202
Like one of these:
I'm pretty sure you want the trans cooler separate since you would want the tranny (under 175 degrees is where i try to keep my tranny) to run cooler than the engine (185 degrees) and the oil cooler runs to the radiator since the oil would be maintained as the same temp as the engine, just makes it more efficient on the cooling side since its from within.
Old 01-31-2012, 12:19 AM   #6
six8burban
Ok, ok...... Got it, thanks
Old 01-30-2012, 11:07 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
you can use an engine oil cooler for a trans, but not the other way around.
Internal tubing size on most trans coolers is too small.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-31-2012, 02:19 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
fwiw seperate is ideal, but the in-radiator trans cooler is extremely common and isn't BAD....simply not as good as running a seperate cooler.
imo if you would ever tow/haul then I'd make sure to run an external, as fluid temps will climb under that kind of load.
Old 01-31-2012, 10:20 PM   #9
clinebarger
The liquid to liquid transmission cooler in the radiator is MORE efficient than a liquid to air transmission cooler.
Running a liquid to air cooler in series with the liquid to liquid cooler is fine, But Never just a liquid to air by itself.
clinebarger is offline   Reply With Quote
Old 01-31-2012, 11:26 PM   #10
mooseknuckles
mooseknuckles's Avatar
....please explain.
mooseknuckles is offline   Reply With Quote
Old 02-01-2012, 10:42 PM   #11
six8burban
Originally Posted by mooseknuckles View Post
....please explain.
Read it atlease 3 more time and u will understand, took me a couple times but I think I understand. :-)
Old 02-01-2012, 10:59 PM   #12
mooseknuckles
I was always led to believe that a separate trans cooler was far superior than having the trans fluid cooled by hot water....
Old 02-02-2012, 09:18 AM   #13
Shon
....please explain.
Please do so, I have mine run from trans to the trans cooler and back to trans, not thru the radiator.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-02-2012, 10:39 AM   #14
Ranger6202
You're right, you do get more temp transfer in liquid to liquid exchange. But we don't want to heat your tranny fluid up with the radiator. Your tranny should be running cooler than the engine, unless you're pulling some serious loads in which you can cool the fluid a few degrees with the radiator (down to 185'ish) and then a few more degrees further via air to liquid exchange. As its already been mentioned here that they do this process. I believe my '06 vmax does this also.
Old 02-04-2012, 07:35 PM   #15
clinebarger
Most auxiliary liquid to air coolers are not even close to being large enough to cool a transmission by itself.
Modern transmissions with aluminum valve bodies perform better when the fluid is around 180 to 190 degrees.
If your running just the liquid to air......The trans doesnt warm up like it should & you run the risk of it overheating in stop & go driving.
I hope none of you guys are running a stall converter
Old 02-01-2012, 10:46 PM   #16
six8burban
Ok I ordered the black nylon braided hose and push to fit AN fittings, jegs sales guy said stainless was overkill?
Old 02-01-2012, 10:49 PM   #17
six8burban
......trans cooler lines I'm referring to.
Old 02-05-2012, 02:13 AM   #18
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I am....but have a trans cooler installed so hot fluid hits the cooler in the radiator 1st, then goes thru the trans cooler, then back to the trans. I also have a trans gauge but haven't hooked it up yet....not sure what port to use on my 200-4r.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-05-2012, 11:11 AM   #19
mooseknuckles
ok...so normal trans operating temp is 180-190* anyway...which would make sense.
Old 02-05-2012, 12:47 PM   #20
ls1nova71
ls1nova71's Avatar
The OEM's use the radiator cooler to also warm the transmission, if you livein a climate where temps get really cold, (i.e. Canada! LOL) it's possible for the trans to run too cool, so running it through the radiator controls the temps with the thermostat.
Old 02-05-2012, 06:42 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yall got me scared. I've got my 4l80e through a fin-tube external cooler rammed low and in the front, has god air flow to it. My rad is a be-cool but only has passes to cool the engine. Is there a good stand-alone cooler I can run to keep from burning my **** out? Luckily I have done mostly highway miles and it never go real warm.
Old 02-06-2012, 12:23 AM   #22
68GMCCustom
I'd think adding an electric fan to the cooler would do about as much as increasing its size?
Kurt -
Old 02-10-2012, 11:36 PM   #23
noonzor
im interested in this as i have yet to get to this point in my build. what i was planning on doing is whats already been stated. trans-->radiator-->air2liquid infront of rad-->back to trans.
ls1nova71 "I AM CANADIAN" lol, and here in edmonton we've been colder than siberia a few times in the passed few years (one solid week of -45*c or colder), but this is negligable because my truck will not see winter.
my truck (turbo'd lq9, 4l80e) will see summer cruises to car shows, and trips to and down the 1320'. is there a "best" way of plumbing or is this another one of those arguable opinion deals? any help or opinions appreciated!
kyle.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 02-11-2012, 04:19 PM   #24
ls1nova71
ls1nova71's Avatar
kyle.
There's another canadian on this thread, that's why I said that. Lol! But the way you said in your first paragraph is the way tthe OEMs run them for towing applications so i would think you'd be fine that way.
