Old 01-30-2012, 10:33 PM   #1
lo72
Truck Junkie
lo72's Avatar
454 Mystery
Ok I'm building a 30 over 99 454 using a zz502 roller cam lifters and 3/8s pushrods. New melling hi volume oil pump rings bearings etc. Now here's the problem I've primed the engine and I'm getting oil to the rockers on the drivers side but nothing, zip,nada to the rockers on the passenger side I turned the motor a number of times. I'm getting good flow to the drivers side but nothing to the passenger. I'm using an electric drill 800 rpms max. I have 40 lbs of oil pressure. I'm really stumped! Any help will be greatly appreciated .
lo72 is offline   Reply With Quote
Old 01-30-2012, 10:36 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 454 Mystery
What type of priming tool are you using?
You need one like this one. The bottom part seals the proper oiling passages to send oil to the entire block.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-30-2012, 10:48 PM   #3
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
One just like your picture. Greg
Old 01-31-2012, 12:39 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
Re: 454 Mystery
There must be an alignment issue with your priming tool. That groove in the lower aluminum piece is there so that oil can flow around it. I'm guessing that that groove is not aligned properly in the block.
Old 01-31-2012, 12:45 AM   #5
gchemist
gchemist's Avatar
Re: 454 Mystery
Can you install the distributor hold down bracket? Is the top flat plate flush with the intake? Was the engine rebuilt?
Old 01-31-2012, 06:53 AM   #6
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
Yeah I'm building the engine I haven't put the intake on yet though.
Old 01-31-2012, 08:37 AM   #7
BigBlocksRule
Re: 454 Mystery
Are all the oil galley plugs in place?
Make sure the ones in the lifter valley are there...had a buddy who built one and left those out. Oil everywhere except where he needed it.
BigBlocksRule is offline   Reply With Quote
Old 01-31-2012, 09:22 AM   #8
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
Yep all the plugs are in the galleys
Old 01-31-2012, 09:27 PM   #9
76Charlie
76Charlie's Avatar
Re: 454 Mystery
Did you check to make sure all oil gallies weren't plugged, like the crank, heads, etc?
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY!
76Charlie is offline   Reply With Quote
Old 01-31-2012, 09:50 PM   #10
78maliburat
Re: 454 Mystery
Spin the crank
78maliburat is offline   Reply With Quote
Old 01-31-2012, 10:14 PM   #11
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
I've spun many times no change
Old 01-31-2012, 10:30 PM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 454 Mystery
Pull the plugs so there is no compression and add the distributor. And hook it up to a battery charger and crank it till some oil comes out the other side.
But honestly once the engine fires within 10 secs the lifters and rockers on both side will have planty of oil. This is why I usually use bearing grease on all surfaces just in case
You should be fine though. Just make sure your using zinc additive or break in oil too
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-02-2012, 01:35 PM   #13
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
Thanks for the info!
Old 02-05-2012, 01:54 PM   #14
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
Solved the mystery. The intake port on the roller lifter has to face the oil galley in the block. I moved them and they are all oiling. Thanks for everyone help Greg
Old 02-05-2012, 02:13 PM   #15
76Charlie
76Charlie's Avatar
Re: 454 Mystery
Good news! always great to solve a mystery
Old 02-05-2012, 02:20 PM   #16
Newtz67
Newtz67's Avatar
Re: 454 Mystery
Very helpful info. Any chance you could post a pic of the lifters the right way and wrong way?
Newtz67 is offline   Reply With Quote
Old 02-05-2012, 02:31 PM   #17
BigBlocksRule
Re: 454 Mystery
Wow, I'd never have thought it would matter in a pressurized galley.
Learn something every day, thanks for that!!!
Old 02-06-2012, 09:48 PM   #18
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
Sorry I already put them back in. Just hold the lifter and turn it till u find the small hole in the side when you put it in the lifter bore make sure the little hole is facing to the rear of the block. You can see the oil galley in the lifter bore before you drop in the lifter. This only applies to roller lifters because the don't turn in the bore as flat tappet lifters do. My bbc is a 99 roller motor the oil flow in the oil galley is rear to front. Thanks again for all the input. Greg
Old 02-07-2012, 12:19 AM   #19
Newtz67
Newtz67's Avatar
Re: 454 Mystery
Ya, I know what your saying, pics are always good though. I was just hoping you had pics for a visual if anyone needed it. Oh well thanks.
Old 02-07-2012, 09:29 AM   #20
BigBlocksRule
Re: 454 Mystery
This still doesn't make sense to me.
Flat tappet lifters rotate, but not very fast. This would mean that they weren't properly oiled except when the hole is facing the direction of oil flow.
I've built several 350's and a few 454's with OEM roller lifters. I never paid any attention to the direction the oil hole was facing, but there's not a chance that they're all in facing the right direction. Not with a 50/50 chance.
I think something else you did either fixed it or there was a big air bubble or something blocking flow to that side.
No matter, it's fixed now and that's the main thing.
Old 02-07-2012, 11:39 PM   #21
Newtz67
Newtz67's Avatar
Re: 454 Mystery
Ya I kinda had a question there too, just didn't have time to post it. If you're running roller lifters, they have the linkage between them right? Why on one side would you have the linkage towards the valley and on the other side have it towards the cylinders? I'm kinda confused on what your saying here, that's why i asked for pics. I'm not building a roller assembly right now but I'm just not sure where the confusion is at...With a non roller lifter motor they do spin and get oil accordingly. On the roller lifters they are stuck in one position. Sounds to me like you don't actually have roller lifters. Of course, I have never built a motor this new soooo, I just don't know...
Old 02-08-2012, 08:13 PM   #22
lo72
Truck Junkie
lo72's Avatar
Re: 454 Mystery
I have roller lifters all right. They are gm lifters that have a retainer to keep them from rotating. I know the aftermarket rollers have a bar. Gm doesn't use that style.
